JL prob in a RSX-S
branvw
Copper - Posts: 90
Posted: October 10, 2006 at 9:32 AM / IP Logged
i have put a sealed JL - 10W1v2 sub with a JL - A1200 amp into an acura RSX-S, the car does have the bose system in, i did not install a new deck.  The input for the amp cam from the rear speaker in the car, i split the wires and ran them into the input of the amp......  The system works ok but i truly expect alot more from this system it is not hitting hard at all! is the stock boose creating a problem, do i need to change the wiring? HELP!
DYohn
Moderator - Posts: 10,741
Posted: October 10, 2006 at 10:36 AM / IP Logged
The signal to your rear speakers is crossed over (high-passed) in your head unit.  You need to get a signal from the factory sub.
branvw
Copper - Posts: 90
Posted: October 10, 2006 at 10:38 AM / IP Logged
The factory sub has 2 wires that went into it, should splice it so i have all four input wire on the amp hooked up?
branvw
Copper - Posts: 90
Posted: October 12, 2006 at 1:59 PM / IP Logged
are you talking about the amp that is built into the bose subwoofer?
forbidden
Platinum - Posts: 5,354
Posted: October 12, 2006 at 2:16 PM / IP Logged
Yes he is. You are far better of purchasing a good LOC to integrate the factory amplified system into the new amp.
integratyper934
Copper - Posts: 150
Posted: October 15, 2006 at 9:11 PM / IP Logged
i have never had a problem using the factory rears and not getting enough bass......did you put the signals in phase if not you will cancel out the signal.
branvw
Copper - Posts: 90
Posted: October 16, 2006 at 1:12 PM / IP Logged
took apart the factory sub, hooked it into the JL amp..... BUMP BUMP BUMP theres your problem!!! WOW amazing, sounds great and hits VERY HARD!
Friday, November 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
