how many watts do u get when u wire 2subs
ggalan
Posted: November 06, 2006 at 11:27 PM / IP Logged
i am wiring 2 subs that are 4 ohm dual voice coil in parallel/parallel to get a 1 ohm load they are both 1000 watts  and i want to figure out how many watts do i get at the end.
gg
DYohn
Platinum - Posts: 10,741
Posted: November 06, 2006 at 11:33 PM / IP Logged
You "get" how ever many watts the amplifier is capable of producing.  If you connect two woofers, the power is divided between them.  If you use one woofer, all the power is used by one.
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
