battery isolator
joey2714
Member - Posts: 39
Posted: November 13, 2006 at 3:19 PM / IP Logged
I have a 2006 ford explorer, i have 4000 watts RMS running through the stereo, and im going to add two kinetik 2000 power cells to the trunk.  i have a 300 amp fuse under the hood.  i was going to add an isolator, but i cant find one above 200 amps.  what size do i need? and where can i get it? thanks
Pioneer Avic D3
Rockford Fosgate T15004
Rockford Fosgate T20001BD x 2
15" Fully Loaded Fi BTL x 2
6" Eminence Alpha Mids x 16
Eminence APT-80 Tweeters x 16
260 Amp Iraggi alt
Kinetik 2400 x 3
haemphyst
Platinum - Posts: 5,059
Posted: November 13, 2006 at 5:39 PM / IP Logged
Do you have a 300A alternator? If not, all you have to do is make certain your isolator is rated at more than the alternator. If you have not upgraded your alternator, and you are still running a stocker, the 200A isolator will do fine.
normalicy
Member - Posts: 48
Posted: November 16, 2006 at 10:56 AM / IP Logged
Yeah, 200A is fine. If necessary, you can get 2 & run them in parallel.
What is normal anyway???
kymadan
Member - Posts: 39
Posted: November 17, 2006 at 3:01 AM / IP Logged
Does the Isolator have to be rated higher than the alternator? What if I have an 80 Amp alternator, and I get an 80 Amp Isolator? Will that be okay?
haemphyst
Posted: November 17, 2006 at 6:07 AM / IP Logged
Doesn't allow much leeway... If you have an 80A alternator, I'd step up (for the extra $1.50) to a 100A isolator model.
kymadan
Member - Posts: 39
Posted: November 17, 2006 at 11:28 AM / IP Logged
Makes sense, it's just that I found an 80 Amp isolator for really cheap. Now I gotta check out the 100 Amp isolators.
jpease
Member - Posts: 9
Posted: November 17, 2006 at 2:59 PM / IP Logged
rookie question what are the benefits in having an battery isolator?
normalicy
Member - Posts: 48
Posted: November 17, 2006 at 5:47 PM / IP Logged
Mainly, it keeps the main battery that runs the car seperated from the stereo's battery so that if you run it down, it won't drain the car's battery.
aznboi3644
Gold - Posts: 2,600
Posted: November 17, 2006 at 10:45 PM / IP Logged
Um...there aren't really any benefits...it helps keep the main battery under the hood charged if you're playing the system without the engine running. It won't add any power to the system
jpease
Member - Posts: 9
Posted: November 17, 2006 at 11:02 PM / IP Logged
thanks!
