Does Illuminate wire exist? 04 Silverado
decipha11
Member - Posts: 6
Posted: November 14, 2006 at 6:48 PM / IP Logged
I recently installed a pioneer deck that is equipped with a ORANGE / White ILLUM wire. Does this wire exist on my factory harness or is there a relay somewhere i can connect to interact with my dimmer switch?
NowYaKnow
Gold - Posts: 1,217
Posted: November 14, 2006 at 9:45 PM / IP Logged
Not required, but if you want to connect that to the brown positive park light wire in the vehicle. Should be in the drivers kick panel.
Mike
decipha11
Member - Posts: 6
Posted: November 14, 2006 at 11:30 PM / IP Logged
Will wiring it to this wire allow me to control the brightness using the dimmer?
geepherder
Platinum - Posts: 3,668
Posted: November 15, 2006 at 5:14 AM / IP Logged
No, the illumination wire will cause the deck's display to dim a predetermined amount when the parking lights are lit. If your deck does not have a dimmer wire, this is the best you can do short of dissassembling the unit and voiding the warranty, etc.
decipha11
Member - Posts: 6
Posted: November 15, 2006 at 12:57 PM / IP Logged
Does anyone have a diagram of where the brown parking wire exists?
KarTuneMan
Platinum - Posts: 7,056
Posted: November 15, 2006 at 4:46 PM / IP Logged
Parking Lights+ brown   +   driver kick panel
decipha11
Member - Posts: 6
Posted: November 15, 2006 at 5:59 PM / IP Logged
Would that be Instrument Panel, Center Panel, or Underhood?
KarTuneMan
Posted: November 15, 2006 at 6:14 PM / IP Logged
down next to your left ankle.
cntrylvr79
Silver - Posts: 582
Posted: November 15, 2006 at 7:49 PM / IP Logged
Behind that plastic piece by the hood release.
Cause I'm So white and nerdy...
First Class Certi-fried installer
decipha11
Member - Posts: 6
Posted: November 27, 2006 at 5:53 PM / IP Logged
I removed the plastic cover and found the panel but which wire am i looking for? Does anyone have a diagram?
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
