15in SPL sub
hurtado_roberto
Copper - Posts: 196
Posted: December 10, 2006 at 10:43 PM / IP Logged
I'm looking for a single 15" or 12" subwoofer for high SPL and some SQ.  I'm planning on building a ported box and I don't want to take up a lot of trunk space so I'm looking for a single woofer.
My amp outputs 800RMS at 4ohms bridged but it's not operating at full capacity right now since my alternator only outputs 70amps.  An alt replacement is soon to come.
I'm looking for at a price range of $150-250.  I'm currently devating between two RF subs; the P215s8 and the P315D2.  I want to go with the P2 because WinISD does not show a considerable SPL difference between the two.
If you want more SPL at lower volume you should pick a subwoofer with a higher SPL value at 1W right.
Poly Dollies
splaudio
Copper - Posts: 237
Posted: December 12, 2006 at 7:20 PM / IP Logged
not a whole lot of power there or great impedence to pick. cerwin vega V-max,quantum audio QC will both work nicly. if ur looking for spl the quantum qcsvc4 15 has a xmax of 21mm and is rated for 1krms. they get loud and sound ok doing it and will no problem fit ur price range. look me up SPLaudio78@hotmail.com
jeffchilcott
Platinum - Posts: 2,483
Posted: December 12, 2006 at 7:33 PM / IP Logged
For the power you have I would recomend the Kicker L5 12 or 15
We just installed a 12" L5 in a durango this last weekend, and it was being powered by a Kicker zr600 (600WRMS@4OHM)
It was capable of hitting 143.6db @ 45hz with a completly streetable setup.
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
aznboi3644
Gold - Posts: 2,600
Posted: December 12, 2006 at 10:28 PM / IP Logged
I'd get this and try it out
Dayton 15 inch high output subwoofer
jonathancullen
Silver - Posts: 282
Posted: December 13, 2006 at 6:43 AM / IP Logged
why does everyone put up dayton. ive never heard of them. are they just that good or are they good for the price?? they look old but thats just the looks, how well do they perform?
kicker guy
Copper - Posts: 86
Posted: December 13, 2006 at 11:37 AM / IP Logged
I have never heard them... so i wouldn't recommend them. I would agree with Jeff get an L5
jonathancullen
Silver - Posts: 282
Posted: December 13, 2006 at 1:58 PM / IP Logged
another question lol. ive heard an L5 and it was nice, but how much better is an L7. say the 12 inch models powering them fully in the same box?
jeffchilcott
Posted: December 13, 2006 at 2:41 PM / IP Logged
for the new 06' l7's I would put less then 1000 to them
with 800 I would really go with an L5
2007 World Record
jonathancullen
Silver - Posts: 282
Posted: December 13, 2006 at 4:07 PM / IP Logged
jeff how much louder is an L7 then an L5?
jeffchilcott
Posted: December 13, 2006 at 4:18 PM / IP Logged
depends on box and power.     on lower power the l5's will be louder approx 1000 and lower the L5's will be louder.
1000 up per sub the L7 will start to show.
I only noticed a gain using the L7s when I was getting over 1500 per sub...then I was starting to have issues with the L5's holding up for long peroids of time
The L7's I run normally at 3300 per woofer, and thats on 10's
Just remember I only give my equipment a 2 second burst then its done.
For street use right now I have a single ZX1500 running on 18 volt at 1 ohm....No you cannot run these amps this way out of the box, I had to special order mine from kicker, but That runs about 1100 per woofer for street use
2007 World Record
Page of 5
