power output?
old_skool
Member - Posts: 15
Posted: January 10, 2007 at 11:09 AM / IP Logged
Quick question.........
If I run a pair or subs in parallel and connect them to a mono amp will my amp power essentially be cut in half.?
(ie. Run 2 4ohm DVC subs in parallel (1 ohm load) and my amp is 500W at 1 ohm, am I getting 500W to each sub or 250W to each sub?)
DYohn
Platinum - Posts: 10,741
Posted: January 10, 2007 at 11:22 AM / IP Logged
Your amp can put out whatever it can put out.  If you connect one speaker to it, all the power will be used by one speaker.  If you connect two, the available power will be split between them.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
