can 2 amps power 1 set of subs?
shineman
Posted: January 26, 2007 at 5:23 PM / IP Logged
This may be a stupid question but I thought I'd still ask.
Can you wire 2 amps into one set of subs?  I have 2 different amps(one Sony and one Blaupunkt) that together would make 700W RMS and 2 dual 4 ohm voice coil  Calarion subs,  can I wire both amps into these subs?
ive never heard of this but i want to know If i can use both amps before I sell one.
        Thanks for any help
        Shineman
duct tape
Copper - Posts: 125
Posted: January 26, 2007 at 5:46 PM / IP Logged
you could wire one sub to one amp, and the other sub to the other amp.  that is assuming that each amp could handle the impedance of each sub.  that being said, its not a good idea.  one amp will have more power than the other amp and you could have cancellation issues.  you are better off just picking one amp and wiring them both to that amp.
aznboi3644
Gold - Posts: 2,600
Posted: January 27, 2007 at 2:25 AM / IP Logged
simply put...yes you can
But most likely it won't sound good...I'd sell both amps and get one to suit the woofers and the impedance load
stevdart
Platinum - Posts: 5,816
Posted: January 27, 2007 at 12:43 PM / IP Logged
List the equipment you are asking about.  The forum doesn't know whether these two amps are similar, different types or what.
  • If they are both class D mono amps, go ahead and put a parallel-wired sub onto each one.
  • If they are different types of amps, pick the one that is appropriate for your needs and use it only.  See https://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42
  • And, if they are both two-channel amps, series-wire each sub and bridge one sub per amp.
shineman
Posted: January 27, 2007 at 4:38 PM / IP Logged
Thanks for the help. sorry I didn't include all the information.
There both 2 channel amps, and both are stable at 4ohm bridged.  So with my dual 4ohm voice coil subs I wouldn't be able to use both amps because of the ohm load.
I think I'll stick with the 400W and call it good.
        Thanks again
        Shineman
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
