my amp cut out on me
joeydada
Member - Posts: 22
Posted: February 05, 2007 at 6:56 PM / IP Logged
First off -
My sub amp shutdown on me yesterday after work. Checked outputs on HU and they operating correctly. Metered my ground, battery, and remote connections.....all operating correctly.
I am running a RF punch 125.2(2 channel 75watt rms per channel/250 rms bridged). I have my amp bolted down to my box. I never noticed before, but there is no external fuse on this amp that i can see. Is there one inside amp case? under?
My speaker load is a 4ohm 150 rms max, so the amp can easily handle this. I know these amps have x-cards in them. Could this have blown a component possibly? is this common?
Just lookin for a lil input before i start un-bolting everything tomorrow p.s this amp never runs hot and showed know signs of malfunction
thnx
2006 xlt ford ranger
DYohn
Platinum - Posts: 10,741
Posted: February 05, 2007 at 7:00 PM / IP Logged
Did you change anything before it quit working?  How long have you had the amp and was it working fine before?  Equipment does break and wear out, you know.
joeydada
Member - Posts: 22
Posted: February 05, 2007 at 7:02 PM / IP Logged
ive o had for 2 years, but only used 3 months - it is probably like 4 years old
The led light is on and operating on amp aswell
joeydada
Member - Posts: 22
Posted: February 05, 2007 at 7:03 PM / IP Logged
didnt change anything either
