lanzar amps, good or not?
samuelsteven
Copper - Posts: 123
Posted: February 22, 2007 at 8:37 PM / IP Logged
I was looking at sum amps on ebay and i came across this Lanzar Vibe 3100D, rated at 3000 watts. Are these amps actually putting out 3000 watts? or are they way over rated? Heres the link.
http://motors.search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&fcl=3&catref=C6&from=R10&satitle=Lanzar+vibe&sacat=38638%26catref%3DC6&sargn=-1%26saslc%3D2&sadis=200&fpos=77502&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=2%26fsoo%3D2&coaction=compare&copagenum=1&coentrypage=search
haemphyst
Platinum - Posts: 5,059
Posted: February 22, 2007 at 9:46 PM / IP Logged
ummm... Where do I start? Let's just say "overrated" is putting it nicely. Lanzar USED to be only moderately good, but now they are classed with Audiobahn AFAIAC.
samuelsteven
Copper - Posts: 123
Posted: February 22, 2007 at 10:04 PM / IP Logged
That is a very nice way to explain it, i completely understand
aznboi3644
Gold - Posts: 2,600
Posted: February 22, 2007 at 10:06 PM / IP Logged
Lanzar sucks....that amp is prolly fused at 60 amps...lol
I thought EBAY links were blocked from this site??
jmelton86
Gold - Posts: 1,228
Posted: February 22, 2007 at 10:17 PM / IP Logged
haemphyst, you said Lanzar amps are now classed with Audiobahn AFAIAC. What is this? Im assuming its better than "moderately good". I have a Lanzar amp -Vibe241 (1000watts max, yeah right!)- and ill say that it is alright. The only way I could get decent power from it is when I hooked it up in tri-mode. I had one KickerComp 10 (4Ohm) hooked to each side in stereo then a RF P1 12 (4Ohm) bridged. -Someone told me to use inductors on each speaker b/c the amp is designed for tri-mode with 2 4Ohm upper-frequency speakers on stereo then a 4Ohm woofer bridged. Is this true? I had the amp on full range b/c of my 80Hz LPF in my HU. Now I have it bridged on the 10's (parallel= 2Ohms). Though this is not recommended (and I wouldn't recommend it), it works! The amp gets warm but not unpleasantly hot. I've only popped the internal fuses once (no low-impedance protection) only b/c of a bass CD. Is this at all okay as long as the amp doesn't get too hot?
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
aznboi3644
Gold - Posts: 2,600
Posted: February 23, 2007 at 12:15 AM / IP Logged
Um...Lanzar and Audiobahn are not Moderately good...they are crap. I've had a 600 watt max lanzar amp...claimed like 320 watts rms...with a 20 AMP FUSE!!!!! yeah right.
Both of them are crappy amp manufacturers...waste of money. That power you are getting jmelton is most likely a dirty clipped signal
jmelton86
Gold - Posts: 1,228
Posted: February 23, 2007 at 12:48 AM / IP Logged
aznboi3644; suprizingly enough, very little clipping- if any. The signal it gets is from an Alpine CDA-9830. The interconnects are MonsterXLN, which have a wire -I guess that just runs between the two sides- that is grounded at the HU side. Now, im not trying to defend Lanzars' suck-a** products, but since i've had my Vibe241 hooked-up 2Ohm bridged (Don't try this at home!) to 2 KickerComp 10's, i've been very impressed at it's performance and ability to keep...working.
Big3 in 1/0G
1/0G to GTO14001
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
