contact glue
james048a
Member - Posts: 13
Posted: February 23, 2007 at 1:17 PM / IP Logged
My question is would any spray gun work for 3m RED / black can contact cement? i currently have 3 HVLP, 2 are cheep. Im going to be getting ready to re-do my door pods (here is the current one) Im going to upgrade to a 3-way, 6.5", 4", tweeter for the door.
* Alpine IVA-D310,
* Alpine NVE-N872A nav,
* Alpine PXA-H701,
* Alpine MRV-F345, MRD-M1005
* Alpine Type-X 10"
mike12volt
Copper - Posts: 98
Posted: February 23, 2007 at 9:55 PM / IP Logged
Depending on viscosity of particular compound, not all paint sprayers can accept such without clogging the nozzle. I would just get some cheap sprayer from Lowes hardware store in case the glue would not clean out.
coppellstereo
Silver - Posts: 785
Posted: February 24, 2007 at 12:25 AM / IP Logged
im confused - what are you using the glue for?
james048a
Member - Posts: 13
Posted: February 24, 2007 at 11:27 AM / IP Logged
Thanks mike12volt for the info, ill try one of my cheap sprayers i have.
"im confused - what are you using the glue for?"
The glue is used for appling vinyl/carpet to your project. Im redoing my door pods to add a 4" or 5.25" mid range to my current 6.5" Plus couple other vinyl projects. Spaying it on is alot earyer then brushing it on.
* Alpine IVA-D310,
* Alpine PXA-H701,
* Alpine Type-X 10"
forbidden
Platinum - Posts: 5,354
Posted: February 24, 2007 at 1:43 PM / IP Logged
3M products contact cement  are also available in a aerosol can and would take care of this job as well. (for those of you that do not have air compressors).
