head unit with subwoofer out rca
tomamabomb
Posted: March 06, 2007 at 3:15 PM / IP Logged
im installing an Innovatek IN-402DTM dvd player.
instead of having 2 RCA out for the subwoffer there is only 1
unit has Front and Rear RCA (red,white,yellow) Outputs
an RCA (red,white, yellow) Input
the subwoofer out
and a coaxial out
how would i go about hooking up the RCAs from the amp to the radio ? (i am not using the front or rear outputs, ive connected the speakers directly to the headunit)
there is no 'remote' wire either, but im assuming i can tap into the acc. wire to draw power, correct?
thank you for your time
KarTuneMan
Platinum - Posts: 7,056
Posted: March 06, 2007 at 6:30 PM / IP Logged
sub out.....get a Y cable.
tomamabomb
Posted: March 07, 2007 at 9:59 AM / IP Logged
figured it was that simple.
thanks for your time
