2003 Wiring Harness
muscleshop
Posted: February 06, 2003 at 11:23 PM / IP Logged
Anyone know WHEN a wiring harness for a 2003 Silverado will be available??  Trying to put my Alpine head unit in the new truck, since the factory radio stinks!  Nobody in the Hoston area has them yet (at least nobody I have talked to...lol)
"If muscles were chocolate, I'd be Willy Wonka"
bberman1
Gold - Posts: 2,314
Posted: February 07, 2003 at 10:26 AM / IP Logged
might want to contact  PAC http://www.go2pac.com or Metra http://www.metraonline.com
Chris Luongo
Platinum - Posts: 3,746
Posted: February 08, 2003 at 8:05 AM / IP Logged
What stinks about the factory radio?  Delco radios are among the best.  It'd take a lot to get me to downgrade to aftermarket, unless the factory unit had no CD player.
The wiring harness houldn't be any different from a harness for a 2000+ Cavalier, or a newer Saturn harness.  If you use a Saturn harness, the wire colors will be incorrect, but your truck still uses standard GM wire colors, so it'll be easy to figure out.
Also, there is no switched power at the radio, as the on/off gets controlled by GM's databus.  Remove the driver's underdash, located (and test) the large brown wire behind the fuse box; this is accessory power.  Attach a 10-amp fuse, and run a length of wire up to the radio.
