dvc parallel wiring 2 different ways
quarantine
Posted: March 28, 2007 at 3:30 PM / IP Logged
from the diagram, both are parallel wired correct? is there a difference of any sort? please explain. do you prefer one over the other? is there a difference in final load? I'm a bit curious to know, and a search did not help. thanks for the input
dvc parallel wiring 2 different ways -- posted image.
stevdart
Platinum - Posts: 5,816
Posted: March 28, 2007 at 5:48 PM / IP Logged
Both illustrations show parallel connections of the same three points of like polarity.  I prefer the top because there would ultimately be less wire length, but use whichever way is most convenient for you in your particular application.
roo-dog
Copper - Posts: 124
Posted: March 28, 2007 at 6:08 PM / IP Logged
yeah, both the same.  the only advantage of the latter would be that you could change the configuration (and impedence) by re-wiring at the amp, without rewiring subs.  however, this is for the most part useless, unless you are running a competition amp that is capable of very low impedences.  most systems are designed to be wired up in only a certain configuration.
i had an old phoenix ms-2125 that i had wired in this fashion.  driving around i ran it at 2-ohms, and for shows, i would re-wire it to 1/2 ohm and show off what a 250 watt amp can do.  i wish i had known more about relays back then- i could have just ran a switch to some relays and never touched the wires with the same effect (lol-live and learn)
(4)g5-1244, (4)gtr12, (2)ppipcx2400, (1)pcx4125, (1)pc4800.2, (3) pair mb quart 6.5"Q, (4)optimas, alumapro (1)5 and(1)15 farad cap, premier deh-p860mp, pioneer xm -dual H.O. alternators
quarantine
Posted: March 28, 2007 at 7:01 PM / IP Logged
thank you for replies. As of now my sub is wires as the second illustration. I was thinking of switching to the first, because thats how I see a parallel connection on different websites. So if they are the same, then a change wont be necessary.
82urq
Member - Posts: 15
Posted: March 29, 2007 at 11:15 AM / IP Logged
I would like to know more about how to set up relays to do that?
rudydapimp
Copper - Posts: 390
Posted: March 29, 2007 at 1:48 PM / IP Logged
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
