amp in diesel w/2 batteries
cory davis
Posted: April 18, 2007 at 8:21 PM / IP Logged
I have a 1997 gmc sierra diesel. Is it ok to run my amp (200w) off the secondary battery, on the top post (the side posts are used for vehicle connections)? I am currently running this way with no noticed ill effects.Thank you in advance for your consideration. Also, sorry if this is a repeat question, I searched the forum but didn't find the answer.
haemphyst
Platinum - Posts: 5,059
Posted: April 18, 2007 at 8:58 PM / IP Logged
Either post can be used for any connection - they are electrically the same. As long as you have the mechanical connection, you can go either place.
cory davis
Posted: April 18, 2007 at 9:30 PM / IP Logged
Thank you for the rapid response. After reading over my quesion again, I want to clarify, that I really need to know if it is ok for me to run the amp power from the diesel's 2nd battery, not the primary one. Thank you again.
forbidden
Platinum - Posts: 5,354
Posted: April 18, 2007 at 10:03 PM / IP Logged
It is fine running from either battery. No need to change anything at all. Make sure that you have a fuse on that power line no further than 18" from the battery.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
