2 x 1 ohm or 1 x 2 ohm?
T.Hill
Copper - Posts: 268
Posted: May 24, 2007 at 3:20 PM / IP Logged
I have a 15" tc-3000 in a 1.8cuft sealed box getting 750w right now. I'm looking getting a MTX TA91002 which is rated at 2x750w @ 1ohm or 1500w bridged @ 2ohm. same wattage, but I'm just wondering if it would be better to run it 2x1ohm or 1x 2ohm. any thoughts....thanks in advance
Pioneer DEH-P980BT, Zapco DCREF1000.4,Pioneer TS-C520PRS, Adire Extremis, MTX TA91002, TC Sounds TC-3000 15"
DYohn
Moderator - Posts: 10,741
Posted: May 24, 2007 at 3:42 PM / IP Logged
I always prefer to operate subwoofer amps in mono (bridged stereo is mono) if possible.  Does it make a difference?  Not really.
haemphyst
Platinum - Posts: 5,059
Posted: May 24, 2007 at 3:44 PM / IP Logged
What's the voice coil configuration? If dual 1 ohm coils, either way. If dual 2 ohm coils, 2 ohms per channel or bridged to 4 ohms. If dual 4 ohm coils, 4 ohms per channel or 2 ohms bridged (the 1 X 2 ohm option). Those are your only safe options, but I can only guess, as I don't know what your woofer configuration is.
T.Hill
Copper - Posts: 268
Posted: May 24, 2007 at 4:30 PM / IP Logged
Sorry I forgot to include the config. It's quad 2ohms coils. I don't think this amp is dual mono. It's just a 2 channel amp that I want to run subs on.
haemphyst
Posted: May 24, 2007 at 6:20 PM / IP Logged
With quad 2 ohm coils, you can go 1 ohm per channel, OR bridge it into 2 ohms... It won't matter, electrically, but as DYohn sez, he prefers bridged to stereo.
T.Hill
Copper - Posts: 268
Posted: May 25, 2007 at 3:18 PM / IP Logged
Ok then, that's the way I was leaning. I just needed some pro advice. thanks again for the help
Friday, November 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
