hifonics 2006d info
westlos213
Member - Posts: 10
Posted: June 12, 2007 at 1:36 AM / IP Logged
i currently have 2 kicker l7 12'' 4ohm  wired paralell in a ported box now i have only the positive and the left negative used and then im running speaker wire from one sub to another as opposed to running wire from the amp to each sub individually,now will this result in a 1ohm load? does this sound right? will i mess something up? the amp is not bridgeable but 1ohm stable......the amp is a Hifonics mono 2006d
aznboi3644
Gold - Posts: 2,600
Posted: June 12, 2007 at 1:53 AM / IP Logged
if the coils are still in parallel than yes
westlos213
Member - Posts: 10
Posted: June 12, 2007 at 2:04 AM / IP Logged
so even though the amp is not ''bridgeable'' i can still run it like this?, thanks for the reply
aznboi3644
Gold - Posts: 2,600
Posted: June 12, 2007 at 11:26 AM / IP Logged
yes...as long as all the +'s are wired to each other then to the amps + and all the -'s are wired to each other and then to the amps - than it is still all in parallel
westlos213
Member - Posts: 10
Posted: June 12, 2007 at 6:33 PM / IP Logged
perfect, thanks.. i kinda figured that but i wasnt sure, abother thing on this amp the manual states to wire the subs negative left and positive far right ,shouldnt it be the other way around?
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
