2000 chevy impala, stereo wiring
dustin23
Copper - Posts: 54
Posted: July 11, 2007 at 10:43 PM / IP Logged
i am installing a new stereo in my 2000 chevy impala and i am having a problem finding the amp turn on wire or the ignition wire from the factory radio harness.
dustin213
duct tape
Copper - Posts: 125
Posted: July 11, 2007 at 11:27 PM / IP Logged
you wont find a 12 volt accessory wire on the factory radio harness, GM uses a data bus system to turn the radio on.  you can either go to the fuse panel or to the ignition harness to get your turn on wire.   or you could purchase a line out converter that has a built in turn on lead.   like this one
http://www.installer.com/item/display_item.php?it=svenr
dustin23
Copper - Posts: 54
Posted: July 12, 2007 at 9:23 AM / IP Logged
does any one know the radio wiring diagram for the 2000 chevy impala
dustin213
dustin23
Copper - Posts: 54
Posted: July 12, 2007 at 12:34 PM / IP Logged
why is it when i try to install an after market radio and remove the factory radio from my 2000 chevy impala, i dont receive any iginition power. i only read 12 volts on that wire when the factory stereo is connected to the harness.
dustin213
rudydapimp
Copper - Posts: 390
Posted: July 12, 2007 at 1:28 PM / IP Logged
data-bus system.  those cars do not have a switched 12v in radio harness.  you have to tap another source.
dustin23
Copper - Posts: 54
Posted: July 12, 2007 at 2:31 PM / IP Logged
what other source can i use?
dustin213
duct tape
Copper - Posts: 125
Posted: July 12, 2007 at 2:38 PM / IP Logged
ignition harness or fuse box or you can but an 80 dollar data bus adapter that will retain your door chime.
dustin23
Copper - Posts: 54
Posted: July 16, 2007 at 11:14 PM / IP Logged
when contecting an aftermarket radio to a 2000 impala, will i lose any functions to the car other then the door chime. I've rencently heard that the factory radio controls different aspects of the car other than the radio functions. is this a true statement. is it possiable to remove the factory radio from the impala?
dustin213
slimatmim
Member - Posts: 7
Posted: July 30, 2007 at 12:12 AM / IP Logged
Yes. You can remove the radio but you will have no more door chimes. So if you want an easy way of hooking up your radio and keep your chimes use a peripheral gmco interface
slimatmim
Member - Posts: 7
Posted: July 30, 2007 at 12:18 AM / IP Logged
White wire in radio harness
