dyna quest amplifiers
melea
Posted: November 08, 2007 at 7:05 AM / IP Logged
i have a dyna quest power amplifier and set it in my car an old model mitsubishi lancer,but my problem is everytime switch it on to listen to a radio in about 5 minutes it will shutdown and before that i have power sub speaker sony explode 1500 watts that connect to my amplifier and my question is what is the problem with that
haemphyst
Platinum - Posts: 5,059
Posted: November 08, 2007 at 9:56 AM / IP Logged
If I understand your question compleletly, it could be many things... Low voltage, overheating, too low an impedance connected to it, defective amplifier...
What have YOU done to troubleshoot it?
coppellstereo
Silver - Posts: 785
Posted: November 08, 2007 at 3:39 PM / IP Logged
Look to see if there are any lights lit on the amplifier when it shuts down. I bet it is going into protection from overheating. Check your ground and your impedance load. As well as punctuation.
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
