2001dodge ram, cd player
amanburr
Posted: December 02, 2007 at 7:01 AM / IP Logged
i have a 2001 dodge ram pickup i put in a new cd player, everythings works. The sound works on am and fm radio, but the cd playerwill show that its playing but there is no sound. It is not the stereo it work it is something to do with the truck wirring
12!@
Platinum - Posts: 13,726
Posted: December 02, 2007 at 9:32 AM / IP Logged
You connected the Blue wire of your radio to the Blue wire of your Vehicle harness.  You need to connect the Blue\White wire of your radio to the blue wire of the vehicle harness.  The blue wire is the power antenna wire, it has 12 volts on it only when listening to the radio.  The Blue\White is the amplifier turn on wire, it provides 12 volts to turn on the factory amp anytime the head unit is powered up.  Your factory amp is turning off when you listen to CDs.
amanburr
Posted: December 02, 2007 at 8:23 PM / IP Logged
thank you
12!@
