Need Double Pulse in Unlock Wire
mnavaid
Posted: April 19, 2003 at 10:36 AM / IP Logged Link to Post Post Reply Quote mnavaid
i installed the Alarm System in my 95 Nissan Maxima and put door locks wire without any relay and door locks when alarm arms, but when alarm disarms its not unlocks the door, i didn't add any relay with door locks, just conect door lock/unlock wire with car's door lock/unlock wire at the switch, i saw in the manual door un locks needs double pulse to unlock the door, what i have to do?? How i can provide the douple pulse to unlock wire when alarm disarms, or i need to put relay, i do have relay that comes with the alarm system but i didnt use in installation, my alarm system works fine, can some budy tell be how i can fix this issue, ????
thanks
profuse007
Gold - Posts: 2,015
Posted: April 19, 2003 at 11:03 AM / IP Logged Link to Post Post Reply Quote profuse007
what kind of alarm unit did you put in?
mnavaid
Posted: April 19, 2003 at 12:18 PM / IP Logged Link to Post Post Reply Quote mnavaid
i bought from ebay that shows night ranger cs-300, i tried to search in internet but didnt find anywhere, but its seems like generic, and i installed it works fine, but not unlocking upon disarming through remote.
(spelling corrected) Need Double Pulse in Unlock Wire -- posted image.
Chris Luongo
Platinum - Posts: 3,746
Posted: April 19, 2003 at 10:10 PM / IP Logged Link to Post Post Reply Quote Chris Luongo
Good alarms can be programmed for double-pulse unlock; read the programming guide for yours and see if it has it.
If you're not using the alarm's trunk-release output, you could tie that into the unlock wire too. After you disarm the alarm (which gives one pulse), you can quickly push and hold the trunk button, which gives the second pulse and unlocks the car.......it is incredibly stupid and inconvient, but it works.
Or you can buy a timer relay, one that will turn two pulses into one. Look around www.go2pac.com, they will probably have something that'll do it.
13volt
Member - Posts: 19
Posted: April 20, 2003 at 2:02 PM / IP Logged Link to Post Post Reply Quote 13volt
There is a way to make a single output unlock into 2+ output. There was a time when the VWs needed that to happen and no alarm company had dbl pulse unlock. I will get you a wiring diagram. It only requires a relay and a 4700 mf cap.
Chris Luongo
Posted: April 21, 2003 at 9:31 PM / IP Logged Link to Post Post Reply Quote Chris Luongo
13volt, I'd love to see that diagram!
NowYaKnow
Gold - Posts: 1,217
Posted: April 22, 2003 at 4:23 AM / IP Logged Link to Post Post Reply Quote NowYaKnow
I have 2 different diagrams that will take a pulse and turn it into a double pulse..My book is at work I will try and remember to bring it home and post them. Course this post alone really doesn't help any Need Double Pulse in Unlock Wire -- posted image.
spl147
Posted: April 23, 2003 at 3:41 PM / IP Logged Link to Post Post Reply Quote spl147
i also need this diagram..
Telemotix
Posted: April 25, 2003 at 12:32 PM / IP Logged Link to Post Post Reply Quote Telemotix
Me too.
JWorm
Platinum - Posts: 2,208
Posted: April 25, 2003 at 9:43 PM / IP Logged Link to Post Post Reply Quote JWorm
That diagram would have been useful when my shop did the 551r. I always hated it when the salesman would sell it for a car that needed a double pulse unlock.
