Posted: April 02, 2014 at 9:28 PM / IP Logged
Posted: April 02, 2014 at 9:53 PM / IP Logged
Posted: April 03, 2014 at 1:59 AM / IP Logged
Posted: April 05, 2014 at 6:47 PM / IP Logged
Posted: May 19, 2016 at 3:01 PM / IP Logged
Posted: May 20, 2016 at 9:03 PM / IP Logged
Posted: May 20, 2016 at 9:09 PM / IP Logged
Posted: May 21, 2016 at 6:24 AM / IP Logged
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Metal Bracket behind Lower Dash Panel. Four Bolts
Side dash panel. Held on with plastic clips.
Lots of room to work.
Parking Light connection behind light switch. Pops out. Three Clips.
PATS Wires and Horn wire.
12 Volts, Ignition, Starter, Accessory wires.
Lock and Unlock wires in Drivers Door Sill.
Dome Light Wire in wire bundle in Drivers Kick Panel. Relay Used.
Antenna Wire behind Door Seal at "A" Pillar.
Brake Wire connection.
Easy Access Grommet in Engine Bay next to Brake Booster.
Tach Wire Connection at Injector.
Viper 4706, New Style Control Center (antenna) and Hood Tilt Switch.
Excellent pictures. Can't beat those 1100F bypass modules - reliable, easy to program and great price. How is the range on the Viper 4706 remotes?
