Pinout for Stock GM Back Up Camera - FYI
knoble
Posted: March 12, 2010 at 6:08 PM / IP Logged
I obtained a new 2010 GM truck tailgate handle with the built in back up camera to connect to my aftermarket radio and is a direct fit for my tailgate.
My only issue was I didn't know what the pinout for the camera was.  There were six wires for this camera and being it was so new I could not find any diagrams for it.  After a few tries I figured out the pinout and thought I would share.
Red - 12V positive
Black - 12V negative
Yellow - Video out +
Brown - Video out -
White - Shield for video wires (yellow & Brown)
Blue - Positive turn on lead (sending 12V+ to it turns on the camera)
dudek38
Copper - Posts: 250
Posted: June 08, 2010 at 4:45 PM / IP Logged
how did u convert the 3 wires to a 2 wire coax?
owner of
Motion Marine & Car Audio
the florida keys
Platinum - Posts: 13,723
Posted: June 08, 2010 at 5:05 PM / IP Logged
Thanks for the info, we have an avalanche coming in Thursday to attempt to get vid from the camera.
knoble
Posted: June 08, 2010 at 7:03 PM / IP Logged
I tied the brown wire and the shield wire together and then soldered an RCA end onto the wires.
Posted: June 10, 2010 at 9:35 AM / IP Logged
2010 avalanche has only 4 wires.  If you cut the grey harness a few inches from the camera, it contains 4 wires.  Red Black White and a shield.  If you look at the plug 8 inches down line where it plugs to the tailgate harness the wiring is a bit different.  Red Black White and yellow.  On the plug white is shield and yellow is video.  I cut the grey cable in order to be able to reconnect if needed, in that harness white is video and shield is shield.
Posted: June 11, 2010 at 9:49 PM / IP Logged
Spent the morning installing a pac piece into an OEM  nav unit, only to find out from PAC that the radio they ordered was already programmed to accept a back up camera.  Removed the pac unit from the deck and had to wire the camera to the brown plug that has a GREEN / WHITE wire at pin 5.  Pin 6 is video and pin7 is video ground.  2010 Avalanche integrated back up camera works great following instructions from above post.
2 back up cameras in 2 days reminds me that I am too old to be sliding around on concrete floors.
dudek38
Copper - Posts: 250
Posted: June 13, 2010 at 12:08 PM / IP Logged
what about if you didnt have the brown(3rd) plug bcuz the video goes to rear view mirror and didnt have factory nav. i added avicd3 and am trying to get / share video w the fact mirror and factory cam in tailgate which doesnt use coax for video, 2010 silverado.
owner of
the florida keys
Posted: June 13, 2010 at 2:01 PM / IP Logged
At the camera, do you not have the colors at the initial post here?
Monday, November 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
