ct 3310 prostart, 1999 dodge caravan
hypertension
Posted: December 24, 2007 at 12:38 PM / IP Logged
Hi,
I'm a newb here and as such would appreciate any help given. :)  My brother in law purchased the Prostart CT3310 and i've installed it for the most part but its not responding.  Here is my wiring, any pics will be added if needed.
6-Pin Main Ignition Wire                Wire On Vehicle                                Location
Red (+12 Battery)                            Pink/Black                                           Ignition Harness
Purple (+ Starter)                             Yellow                                                  Ignition Harness
Red (+12 Battery                             Pink/Black                                            Ignition Harness
Yellow (+ Ignition Output)              Blue                                                       Ignition Harness
Orange (+ Accessories Output)   BLACK/ Orange                                      Ignition Harness
Green (+5th Relay Output)            BLACK/ White                                         Ignition Harness(second accessory)
5-Pin Secondary Wire                   Wire On Vehicle                                  Location
Black (-Chassis Ground)              Bolt                                                        Underdash
Purple (Tach)                                   Grey/Red                                              Coil
Grey (- Hood Switch)                      Fender                                                   Under hood
Orange (+Brake Switch)                WHITE/ Tan                                              Brakeswitch by pedal
Yellow (+12V Parking Light)         GREEN / WHITE                                          At Headlight Switch
12-Pin Accessories Harness
Not connected yet.
I've yet to install the 12-pin Accessories Harness due to the fact that i'd like to see the system atleast start.  Is there something in the Accessories Harness that is needed to be able to start the vehicle?  Once i plug the CT-3310 in it clicks and thats it, i can't get it to accept the remote and i can't get the parking lights to come on with any of the functions to even verify its working.  I would appreciate any help figuring this out.  Thanks again.
hypertension
Twelvoltz
Platinum - Posts: 2,384
Posted: December 24, 2007 at 1:07 PM / IP Logged
1. I would strongly recommend moving that ground to the kick panel, clean all paint and primer from a piece of metal that has no wiring behind it. Use a self tapping screw and a star washer with a ring terminal on the system ground wire.
2. Make sure you follow the programming instructions to the letter...taken from the manual:
"Flashing the Hood Pin
What is Flashing the Hood Pin?
It is a procedure that makes the module go into the programming centre. Once the module is
in the programming centre, the installer has no more than 20 seconds to get into one of the
sub-menus. Failure to do so will result in the module exiting the programming centre
and the installer will have to flash the hood pin once more.
Remember: You can use the Programming Assistance Button
(PAB) instead of the Hood Pin any time the Hood is up.
The Installer … The Module …
1. Press and hold the hood pin for 4 seconds.
2. Let go of the hood pin. Parking Lights “ON”
3. While the parking lights are on, press down the hood
pin once more.
4. Release the hood pin again. “ON” for 20 seconds
5. You now have 20 seconds to select one of the submenus.
Once inside the programming centre, the Installer has a selection of many different submenus.
Once you are in the programming centre, you have the option of the following
menus:
a) Transmitter Programming ………………….. p.10
b) Programming Options …………………..… p.11
c) Honk Horn Timing* (*if available) ………..… p.13
d) Tach Programming …………………..……… p.12
Remember: You have up to 20 seconds, once the parking lights are on solid, to select a submenu,
Failure to do so will result in the module exiting the programming centre and the installer
P. 10 Installation Guide CT-3310
The Programming
Assistance Button (A.k.a.
PAB.)
The PAB is located on the
side of the module. This
push button mimics the
hood pin switch in order to
avoid having to get out of
the vehicle and pressing the
hood pin switch. The PAB
will work only when the
hood is up.
Before Programming a Transmitter
The transmitter is not delivered pre-programmed: it must be programmed after the wiring of
the module is completed.
The module has the ability to retain up to 4 different transmitter codes; if a fifth transmitter is
programmed, the code of the first transmitter will be erased from memory.
How to Program the Transmitter.
1. FLASH the hood pin switch.
Before the 20 seconds have passed, turn the ignition key to the IGNITION ON (RUN) position and
then to the OFF position.
2. Press and hold the LOCK button until the vehicle gives 5 flashes. The module has
stored the transmitter in its memory.
3. Close the hood, to exit."
Keep us posted on your progress.
hypertension
Posted: December 24, 2007 at 2:12 PM / IP Logged
I've cleaned up the ground and installed it as you've suggested and i follow the programming instructions to the letter and the parking light doesnt come on.  Could this be defective?
Twelvoltz
Posted: December 24, 2007 at 2:48 PM / IP Logged
Curiosity question: Did you verify that the pink/black wire(s) provide a constant +12V? DEI is showing that the constant hot in the 99 Caravan is Red, not pink/black. The BLACK/ orange is listed as ignition, not accessory. DEI has been known to list an accessory wire as an second ignition when in fact the wire is an accessory to show that it is a mandatory connection.
hypertension
Posted: December 24, 2007 at 3:51 PM / IP Logged
I've tested the pink/black to be a +12v constant yes.  So for the BLACK/ orange which i have conntected as accessory which should i connect it to then? Splice it with the ignition? or ?  See the green wire on the ct-3310 is used as 2nd ignition/accessory/starter according to the manuel and the wiring i got from Prostarts website says it snot used... i read someone hooked it up to the BLACK/ white so thats what i did, maybe i should remove it and connect it somewhere else?   Also to ask another question i've got the relays for the door locks which the manuel suggests a 250 ohm and 1500 ohm resister to be used, would a 220 or a 270 be good for that as i dont have any resistors and was gonna buy this package http://www.thesourcecc.com/estore/Product.aspx?language=en-CA&catalog=Online&category=Resistors&product=2719018.   Thanks again for the help.
talt
Posted: December 25, 2007 at 5:16 PM / IP Logged
{p class=Msonormal style="MARGIN: 0cm 0cm 10pt"}{SPAN style="FONT-SIZE: 10pt; LINE-HEIGHT: 115%; FONT-FAMILY: 'Arial','serif'; mso-ascii-theme-font: major-bidi; mso-hansi-theme-font: major-bidi; mso-bidi-theme-font: major-bidi; mso-fareast-font-family: 'Arial'"}{SPAN style="mso-spacerun: yes"} Hi Hypertension,{/SPAN}{/SPAN}{/P}{p class=Msonormal style="MARGIN: 0cm 0cm 10pt"}{SPAN style="FONT-SIZE: 10pt; LINE-HEIGHT: 115%; FONT-FAMILY: 'Arial','serif'; mso-ascii-theme-font: major-bidi; mso-hansi-theme-font: major-bidi; mso-bidi-theme-font: major-bidi; mso-fareast-font-family: 'Arial'"}{SPAN style="mso-spacerun: yes"}I am just going thru the same exercise as you are, trying to install same device on similar vehicle – Plymouth G. Voyager 1999. I did not installed the devise yet. In order not to incapacitate my only vehicle I just cutting wires and putting clamps (M/F) on both sides of the wire, connect them back using clamps. Later on I will prepare the device wires with clamps and diodes where required and I wont to connect them to the earlier prepared  (clamped) connections using splitter clamps.{/SPAN}{/SPAN}{/P}{p class=Msonormal style="MARGIN: 0cm 0cm 10pt"}{SPAN style="FONT-SIZE: 10pt; LINE-HEIGHT: 115%; FONT-FAMILY: 'Arial','serif'; mso-ascii-theme-font: major-bidi; mso-hansi-theme-font: major-bidi; mso-bidi-theme-font: major-bidi; mso-fareast-font-family: 'Arial'"}{SPAN style="mso-spacerun: yes"}On the manufacturer site they advise to connect battery to RED wire on Ignition Harness  and not to Pink/Black.{/SPAN}{/SPAN}{/P}{p class=Msonormal style="MARGIN: 0cm 0cm 10pt"}{SPAN style="FONT-SIZE: 10pt; LINE-HEIGHT: 115%; FONT-FAMILY: 'Arial','serif'; mso-ascii-theme-font: major-bidi; mso-hansi-theme-font: major-bidi; mso-bidi-theme-font: major-bidi; mso-fareast-font-family: 'Arial'"}{SPAN style="mso-spacerun: yes"}IMHO it is better to leave wires that stated as “not available” in the wiring diagram not connected at all.{/SPAN}{/SPAN}{/P}{p class=Msonormal style="MARGIN: 0cm 0cm 10pt"}{SPAN style="FONT-SIZE: 10pt; LINE-HEIGHT: 115%; FONT-FAMILY: 'Arial','serif'; mso-ascii-theme-font: major-bidi; mso-hansi-theme-font: major-bidi; mso-bidi-theme-font: major-bidi; mso-fareast-font-family: 'Arial'"}{SPAN style="mso-spacerun: yes"}It also says that  DOORPIN should be connected to yellow at headlight switch, but don’t know what of the device wires should be connected there. The only yellow wire that I found on headlight switch is on connector that placed just behind mirror adjustment button and I am not sure that it is the right wire.{/SPAN}{/SPAN}{/P}{p class=Msonormal style="MARGIN: 0cm 0cm 10pt"}{SPAN style="FONT-SIZE: 10pt; LINE-HEIGHT: 115%; FONT-FAMILY: 'Arial','serif'; mso-ascii-theme-font: major-bidi; mso-hansi-theme-font: major-bidi; mso-bidi-theme-font: major-bidi; mso-fareast-font-family: 'Arial'"}{SPAN style="mso-spacerun: yes"}Let exchange information , it may help {/SPAN}{SPAN style="mso-spacerun: yes"} {IMG src="https://www.the12volt.com/installbay/smileys/smiley1.gif" border="0"}{/SPAN}{/SPAN}{/P}{p class=Msonormal style="MARGIN: 0cm 0cm 10pt"}{SPAN style="FONT-SIZE: 10pt; LINE-HEIGHT: 115%; FONT-FAMILY: 'Arial','serif'; mso-ascii-theme-font: major-bidi; mso-hansi-theme-font: major-bidi; mso-bidi-theme-font: major-bidi; mso-fareast-font-family: 'Arial'"}{SPAN style="mso-spacerun: yes"}p.s. if you close to GTA it is cheapper to by resistors, diodes etc in Sayal and not in SourceCC.{/SPAN}{/SPAN}{/P}{p class=Msonormal style="MARGIN: 0cm 0cm 10pt"}{SPAN style="FONT-SIZE: 10pt; LINE-HEIGHT: 115%; FONT-FAMILY: 'Arial','serif'; mso-ascii-theme-font: major-bidi; mso-hansi-theme-font: major-bidi; mso-bidi-theme-font: major-bidi"}{?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /} {/SPAN}{/P}{TABLE class=MsonormalTable style="BORDER-RIGHT: medium none; BORDER-TOP: medium none; BACKGROUND: white; BORDER-LEFT: medium none; WIDTH: 4810pt; BORDER-BOTTOM: medium none; BORDER-COLLAPSE: collapse; mso-border-alt: outset maroon .75pt; mso-yfti-tbllook: 1184" cellSpacing=0 cellPadding=0 width=650 border=1}{T}{TR style="mso-yfti-irow: 0; mso-yfti-firstrow: yes"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: maroon 1pt inset; PADDING-LEFT: 0.75pt; BACKGROUND: darkred; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; mso-border-alt: inset maroon .75pt"}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{B}{SPAN style="FONT-SIZE: 10pt; COLOR: yellow; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}FUNCTION{/SPAN}{/B}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: maroon 1pt inset; PADDING-LEFT: 0.75pt; BACKGROUND: darkred; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt"}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{B}{SPAN style="FONT-SIZE: 10pt; COLOR: yellow; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}DATACOLOR{/SPAN}{/B}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: maroon 1pt inset; PADDING-LEFT: 0.75pt; BACKGROUND: darkred; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt"}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{B}{SPAN style="FONT-SIZE: 10pt; COLOR: yellow; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}LOCATION{/SPAN}{/B}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: maroon 1pt inset; PADDING-LEFT: 0.75pt; BACKGROUND: darkred; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt"}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{B}{SPAN style="FONT-SIZE: 10pt; COLOR: yellow; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}POLARITY{/SPAN}{/B}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: maroon 1pt inset; PADDING-LEFT: 0.75pt; BACKGROUND: darkred; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt"}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{B}{SPAN style="FONT-SIZE: 10pt; COLOR: yellow; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}PICTURE{/SPAN}{/B}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 1"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}+12 VOLTS{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}RED{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}IGNITION HARNESS{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}+{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 2"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}IGNITION{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}BLUE{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}IGNITION HARNESS{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}+{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 3"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}IGNITION 2{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}NOT AVAILABLE{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 4"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}ACCESSORY{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}BLACK/ ORANGE{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}IGNITION HARNESS{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}+{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 5"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}ACCESSORY 2{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}NOT AVAILABLE{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 6"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}STARTER{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}YELLOW{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}IGNITION HARNESS{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}+{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 7"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}STARTER 2{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}NOT AVAILABLE{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 8"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}TACHOMETER{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}GRAY{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}DISTRIBUTOR{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}AC{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 9"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}INJECTOR{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}NOT AVAILABLE{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 10"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}PARKING LIGHTS{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}NOT AVAILABLE{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}+{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 11"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}BRAKESWITCH{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}WHITE/ TAN{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}BRAKE SWITCH{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}+{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 12"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}CLUTCH BYPASS{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}NOT AVAILABLE{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 13"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}PARKING BRAKE{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}NOT AVAILABLE{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 14"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}HOODPIN{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}NOT AVAILABLE{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 15"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}GLOW PLUG{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}NOT AVAILABLE{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 16"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}LOCK{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}WHITE/ LIGHT GREEN{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}ECM BEHIND FUSE BOX{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 17"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}UNLOCK{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}WHITE/ LIGHT GREEN{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}ECM BEHIND FUSE BOX{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 18"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}TRUNK RELEASE{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}ADD SOLENOID{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}NOT AVAILABLE{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 19"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}ARM{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}WHITE/ RED{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}ECM BEHIND FUSE BOX{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}-{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 20"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}DISARM{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}WHITE/ RED{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}ECM BEHIND FUSE BOX{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 21"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}DOORPIN{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}YELLOW{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}AT HEADLIGHT SWITCH{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}+{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{TR style="mso-yfti-irow: 22; mso-yfti-lastrow: yes"}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: maroon 1pt inset; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}TRUNK PIN{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}NOT AVAILABLE{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal; TEXT-ALIGN: center" align=center}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"}N/A{/SPAN}{/P}{/TD}{TD style="BORDER-RIGHT: maroon 1pt inset; PADDING-RIGHT: 0.75pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #e0dfe3; PADDING-TOP: 0.75pt; BORDER-BOTTOM: maroon 1pt inset; BACKGROUND-COLOR: transparent; mso-border-alt: inset maroon .75pt; mso-border-left-alt: inset maroon .75pt; mso-border-top-alt: inset maroon .75pt" vAlign=top}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Arial'"} {/SPAN}{/P}{/TD}{/TR}{/T}{/TABLE}{p class=Msonormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: normal"}{SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Verdana','sans-serif'; mso-fareast-font-family: 'Arial'; mso-bidi-font-family: 'Arial'"} {/SPAN}{/P}{p class=Msonormal style="MARGIN: 0cm 0cm 10pt"}{SPAN style="FONT-SIZE: 10pt; LINE-HEIGHT: 115%; FONT-FAMILY: 'Arial','serif'; mso-ascii-theme-font: major-bidi; mso-hansi-theme-font: major-bidi; mso-bidi-theme-font: major-bidi"}{SPAN style="mso-spacerun: yes"} {/SPAN}{SPAN style="mso-spacerun: yes"} {/SPAN}{SPAN style="mso-spacerun: yes"} {/SPAN}{SPAN style="mso-spacerun: yes"} {/SPAN}{SPAN style="mso-spacerun: yes"} {/SPAN}{SPAN style="mso-spacerun: yes"} {/SPAN}{/SPAN}{/P}
Please do not copy and paste from a rich text editor like Microsoft Word. Please copy and paste from a plain text editor like Notepad.
talt
Posted: December 25, 2007 at 5:24 PM / IP Logged
Hi Hypertension,
I am just going thru the same exercise as you are, trying to install same device on similar vehicle – Plymouth G. Voyager 1999. I did not installed the devise yet. In order not to incapacitate my only vehicle I just cutting wires and putting clamps (M/F) on both sides of the wire, connect them back using clamps. Later on I will prepare the device wires with clamps and diodes where required and I wont to connect them to the earlier prepared  (clamped) connections using splitter clamps.
On the manufacturer site they advise to connect battery to RED wire on Ignition Harness  and not to Pink/Black.
IMHO it is better to leave wires that stated as “not available” in the wiring diagram not connected at all.
It also says that  DOORPIN should be connected to yellow at headlight switch, but don’t know what of the device wires should be connected there. The only yellow wire that I found on headlight switch is on connector that placed just behind mirror adjustment button and I am not sure that it is the right wire.
Let exchange information , it may help
p.s. if you close to GTA it is cheapper to by resistors, diodes etc in Sayal and not in SourceCC
FUNCTION DATACOLOR  LOCATION  POLARITY PICTURE
+12 VOLTS RED         IGNITION HARNESS +
IGNITION BLUE         IGNITION HARNESS +
IGNITION 2 N/A         NOT AVAILABLE  N/A
ACCESSORY BLACK/ ORANGE  IGNITION HARNESS +
ACCESSORY 2 N/A   NOT AVAILABLE  N/A
STARTER  YELLOW   IGNITION HARNESS +
STARTER 2 N/A   NOT AVAILABLE  N/A
TACHOMETER GRAY   DISTRIBUTOR  AC
INJECTOR N/A   NOT AVAILABLE  N/A
PARKING LIGHTS N/A   NOT AVAILABLE  +
BRAKESWITCH WHITE/ TAN  BRAKE SWITCH  +
CLUTCH BYPASS N/A   NOT AVAILABLE  N/A
PARKING BRAKE N/A   NOT AVAILABLE  N/A
HOODPIN  N/A   NOT AVAILABLE  N/A
GLOW PLUG N/A   NOT AVAILABLE  N/A
LOCK  WHITE/ LIGHT GREEN ECM BEHIND FUSE BOX N/A
UNLOCK  WHITE/ LIGHT GREEN ECM BEHIND FUSE BOX N/A
TRUNK RELEASE ADD SOLENOID  NOT AVAILABLE  N/A
ARM  WHITE/ RED  ECM BEHIND FUSE BOX -
DISARM  WHITE/ RED  ECM BEHIND FUSE BOX N/A
DOORPIN  YELLOW   AT HEADLIGHT SWITCH +
TRUNK PIN N/A   NOT AVAILABLE  N/A
tedmond
Gold - Posts: 4,610
Posted: December 25, 2007 at 6:01 PM / IP Logged
audiovox and scytek lists the following
12 volt constant  - RED
Ignition 1  - DARK BLUE
Ignition 2 -BLACK/ WHITE
Accessory - BLACK/ ORANGE
Starter - YELLOW
Door Lock - WHITE/ dark green in a WHITE PLUG @ BCM (behind fuse box) unlock through 1500ohm resistor
Door Unlock - WHITE/ dark green in a WHITE PLUG @ BCM (behind fuse box) unlock through 250ohm resistor
hypertention, do u live in the GTA? if so go to SAYALS and pick up resistors and relays for cheap. Insted of paying 8 for a relay and 5 for resistors + tax, going to sayals will cost you 10 dollars for 2 relays, crap load of resistor, heat shrink wrap, diodes, wire loom and maybe an LED.
as for programming, i installed the CT3400 in my aunts car, and to be honest, i though it was a PITA to program. i thought i would never finish. dont bother using the hood pin. use the BLACK button on the side of the unit. 20 seconds patience is key. i think its stupid how the company doesnt pre program the keyfobs to the unit. this is why i like compustar and DEI. Prostart are really good units and they are very well priced. Well after you get that badboy programmed, its smooth sailing on from there.
tedmond
Gold - Posts: 4,610
Posted: December 25, 2007 at 6:16 PM / IP Logged
hey talt,
DOOR PIN - BROWN / WHITE (-) @ Lower right side of Drivers kick panel in Gray connector at fusebox.
if you cant get it, there is also a
BROWN / GREEN (-) @ headlight switched. The wire is there because the domelight draws its power from that location.
also, if you got audio in your car, wire up the trunk and hood pins (factory)
FACTORY TRUNK PIN (-) - TAN/BLACK @ fusebox. Located in a 40 Pin connector
FACTORY HOOD PIN (-) - BROWN @ the engine bay (look for the pin, towards firewall or headlight.
PARKING LIGHTS
Parking lights (-) - Light GREEN / WHITE @ light switch.
AS for locks, it is a 1 wire negative locks.
wire up relay like so.
LOCK RELAY
85 - constant 12v
86 - lock output from unit
70 - High Current Ground
30 - to lock wire (WHITE/ dark green) with 1500ohm resistor inline.
UNLOCK RELAY
85 - constant 12v
86 - unlock output from unit
30 - to lock wire (WHITE/ dark green) with 250ohm resistor inline.
hope i helped you guys out. if u need any more info or help, just ask. GOOD LUCK ! make sure u use a DMM !!!
tedmond
Gold - Posts: 4,610
Posted: December 25, 2007 at 6:33 PM / IP Logged
sorry that i keep posting seperate  posts but i always read and see what i missed out and its been too long to edit.
just ground the parking brake wire straight to ground. this saves u time insted of pulling ebrake, the vehicle starts everytime.
BTW, where did you get your diagrams from? some wires are off colour. As for wires, they used to be those colours. the company changed them. so ifu need up to date wiring, i got em'
Thursday, December 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
