97 contour 2 wire pats
Reeceddogg
Copper - Posts: 331
Posted: January 14, 2008 at 1:19 PM / IP Logged
I'm working on a 97 Ford Contour. Directechs states this year car doesn't have a bypass nor does audiovox. But i took it to the dealership and they said it does. I was going to use the 1100f bypass wire the 1B way as stated for the 98 Contour, only to find the ignition cylinder only has 2 wires for the transponder. One wire is black and the other ORANGE / white. I thought these are the TX/RX wire but car ran for 10secs and died. Switched the wire and the same thing. I'm going to upload pics when i can cause there's not a black transponder ring as on most fords. Has Anyone done this car?
Chris Luongo
Platinum - Posts: 3,746
Posted: January 14, 2008 at 2:37 PM / IP Logged
1. Have you successfully gotten the remote starter to work with the key in the ignition?
2. Most of those cars didn't have transponders.......I'm thinking it might be only the V6, but I'm not sure.
Above the radio, is a black panel with the word Contour on it. With the car off and the key removed, is there a flashing red light there?
Reeceddogg
Copper - Posts: 331
Posted: January 14, 2008 at 5:26 PM / IP Logged
Yes it starts and runs with key in ignition and there is a red flashing light.
Reeceddogg
Copper - Posts: 331
Posted: January 25, 2008 at 12:23 PM / IP Logged
Anyone got any ideas.
usabuilt
Copper - Posts: 161
Posted: January 25, 2008 at 12:29 PM / IP Logged
Usually pats systems have 4 wires going to them. sounds like you are tapped into the wrong wires.
Reeceddogg
Copper - Posts: 331
Posted: January 25, 2008 at 2:17 PM / IP Logged
All the pats systen i've worked on have a green plug. There's only one plug, it's black, and has two wires. One black, other ORANGE / white.I used a 1100f. On the ground i just grounded it to a screw. Ignition wire is on the ignition1(which i metered) and the tx and Rx wires have been switched between the the black and ORANGE / white at pats unit.
usabuilt
Copper - Posts: 161
Posted: January 25, 2008 at 2:27 PM / IP Logged
Are their different pats systems? the ones I have seen have 4 wires ground ign tx rx..you could easily dissconnect the plug you have and see if the car start, if it does its the wrong plug..just make sure its not an air bag plug/`
Reeceddogg
Copper - Posts: 331
Posted: January 25, 2008 at 5:10 PM / IP Logged
100% sure it's not for the air bag.
mobile1
Silver - Posts: 479
Posted: January 25, 2008 at 11:33 PM / IP Logged
Have you TESTED the wires? Sounds like they might be a keysense wire you are tapping into. I 'm pretty sure that car doesn't have a transponder in it. What does the key look like? A sure way to tell would be to get a key made for a buck or two from Wally World or a hardware store, and try to start the car. If it starts, no bypass needed.
Reeceddogg
Copper - Posts: 331
Posted: January 26, 2008 at 1:28 AM / IP Logged
Key looks like this 97 contour 2 wire pats -- posted image.. I tried the 97 cent walmart key. Opened the door but won't start car.
