autopage 900 lcd, 2006 silverado
dstyls
Member - Posts: 37
Posted: February 18, 2008 at 9:26 PM / IP Logged
i'm trying to install a alarm in a 2006 chevrolet silverado LT but i don't understand the yellow and black passlock 2 wire,where does that hook up to your factory alarm?i'm using a auto page 900 lcd,thank's for any help
another-kelly
Silver - Posts: 618
Posted: February 18, 2008 at 9:34 PM / IP Logged
not exactly sure what you're asking, but your autopage doesn't interface directly with the truck's passlock II. you would need a bypass to do remote start. www.bypasskit.com
dstyls
Member - Posts: 37
Posted: February 19, 2008 at 7:13 AM / IP Logged
yeah i'm using the directed dei 1700g gm passlock module,it's this the right module that i suppose to use?if not let me know,thank's for anyone help
KarTuneMan
Platinum - Posts: 7,056
Posted: February 19, 2008 at 8:54 AM / IP Logged
I believe the 1700 module reads the passlock thru data. So the actual passlock wires on the truck are not needed.
Look at the instructions for install on the unit... it will say. It also does locks.... I think.
hydroz_23
Copper - Posts: 97
Posted: February 19, 2008 at 4:18 PM / IP Logged
the only connection to car will be purple to purple at diagnostic plug and 12v and ground
dstyls
Member - Posts: 37
Posted: February 19, 2008 at 4:49 PM / IP Logged
from wat purple to wat purple,from the 1700g module purple
hydroz_23
Copper - Posts: 97
Posted: February 19, 2008 at 6:17 PM / IP Logged
the purple from 1700g which is your data output. hook that purple wire to the purple wire at your obd2 connector on the bottom left side of your dash. but make sure you hook up all the other wires to the 1700g before connecting data wire to truck
chris27
Member - Posts: 41
Posted: February 19, 2008 at 6:20 PM / IP Logged
There should be a purple wire on the 1700G.  That wire will hook up to the purple wire on the diagnostic plug under the dash.  That should take care of your locks and passlock.
hydroz_23
Copper - Posts: 97
Posted: February 20, 2008 at 8:33 AM / IP Logged
thats exactly what i just said
dstyls
Member - Posts: 37
Posted: February 21, 2008 at 11:49 AM / IP Logged
the 1700g will light up when plug is plug in right
Page of 3
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
