viper 770 strange issue
dmielken
Copper - Posts: 63
Posted: March 26, 2008 at 12:08 AM / IP Logged
Vehicle is a 2007 Toyota FJ Cruiser, and unit is as posted in subject line, Viper 770 Remote Start/Alarm Combo.
Problem is, when the alarm is triggered, the brain fries. What I mean to say is, when the siren goes off, all it will do is continuously chirp at low volume, and after this point the unit is dead. It will not link to a BitWriter, nor will it go into a Valet or serviceable state of any kind. Have tried two brains, same results.
Wiring appears accurate and the unit functions 100% until the alarm is triggered.
Thoughts?
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: March 26, 2008 at 1:17 AM / IP Logged
I'd suggest testing every wire at the alarm plug and make sure they are all metering properly.  It sounds like something isn't hooked up right.
Chris Luongo
Platinum - Posts: 3,746
Posted: March 26, 2008 at 6:15 AM / IP Logged
I agree with Steven.
I know that on many alarms, when the ground isn't connected, the siren will sound very quietly as you describe.
On all the plugs that enter the alarm's brain, there's just a little bit of metal contact exposed.
Make sure you're putting your test light/meter's probe directly on that metal part. This way, all in one shot, you're testing all possible failure points.
dmielken
Copper - Posts: 63
Posted: March 26, 2008 at 6:58 AM / IP Logged
On this particular unit, do you believe it may be caused by the fact that my siren ground is connected to the same ground as the one in the vehicle? During prep, I ran the ground and Siren +12V Output from the main harness, instead of grounding the siren separately. I usually do this without problems, but then again I don't do a ton of DEI.
Thanks for your quick replies guys, I'll meter the unit this morning before I install a different unit.
onthemoney
Posted: March 26, 2008 at 9:49 AM / IP Logged
Check your brown siren output wire, it seems to be getting grounded out somewhere down the line.
Steven Kephart
Posted: March 26, 2008 at 10:08 AM / IP Logged
That's how I do all my alarms and never have a problem.
dmielken
Copper - Posts: 63
Posted: March 26, 2008 at 3:04 PM / IP Logged
Thanks for the replies, much appreciated.  Issue was solved this morning.  Found the unit was not grounded properly when I checked the connections.  Somehow it was grounding through the Domelight Supervision wire instead of the true ground at the unit.  100% installer error viper 770 strange issue -- posted image.
Thanks again.
Tuesday, January 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
