Posted: May 17, 2008 at 5:15 AM / IP Logged
Posted: May 18, 2008 at 8:16 AM / IP Logged
Posted: May 19, 2008 at 3:09 AM / IP Logged
Posted: May 19, 2008 at 6:06 AM / IP Logged
Posted: May 19, 2008 at 6:44 AM / IP Logged
Posted: May 19, 2008 at 9:36 AM / IP Logged
Posted: May 19, 2008 at 10:25 AM / IP Logged
Posted: May 19, 2008 at 10:33 AM / IP Logged
Posted: May 20, 2008 at 6:19 PM / IP Logged
Posted: May 21, 2008 at 2:16 AM / IP Logged
Wednesday, May 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
The next photo shows the hood release from the inside - obviously that's not a factory carriage bolt holding it in place! The release lever snaps in to the main underdash panel, and it's really easy to break the locking tab if you try to slide it out. I've had this problem on other Toyotas as well. Best solution is to leave it alone and just pull the cable out of it.
Most every other wire for alarm/RS seems to be accessible in that same area, making this a fairly easy vehicle to do.
My one quibble is with the immobilizer setup. I used an XK05 with PKT2 firmware, which I have some gripes about. First is the fact of having to run wires to the ECM which is on the other side of the vehicle and not as easy to connect to. Also, the supplied wiring harness from the XK05 isn't long enough to reach the ECM and the remote start, regardless of where you place the control module. It's annoying to have to extend 4 wires every time I do a Toyota, which I'll bring up to my rep from Trilogix in a day or two.
I wish they'd make a longer harness or a bypass that could be installed entirely on the driver's side.
Further annoying on this vehicle was the fact that my XK05 was defective and I didn't have a spare - this I could chalk up to misfortune and the fact that I don't keep enough inventory for a situation like that. I'll post again when I get that rectified.
