2000 mitsubishi eclipse, viper 791xv
sworrix222
Member - Posts: 15
Posted: May 19, 2008 at 6:57 PM / IP Logged
does anyone know if i need  to bypass anything or need a special module to install a viper 791xv 2way/remotestart..............
KarTuneMan
Platinum - Posts: 7,056
Posted: May 19, 2008 at 7:36 PM / IP Logged
Manual or auto trans? If it's a manual you need a DEI 689M. An interface for the manual transmission. Without this, it should not be installed.
You would also need a trransponder bypass.
sworrix222
Member - Posts: 15
Posted: May 19, 2008 at 7:50 PM / IP Logged
automatic....thanks
fcss
Copper - Posts: 92
Posted: May 20, 2008 at 2:32 PM / IP Logged
your car has a chip in the key so you need a transponder bypass called a 556u you will have to loose a key hopefully you have more then 1 key cause one of your keys has to go inside the 556u.
