00 galant daytime running lights
desh187
Copper - Posts: 310
Posted: June 01, 2008 at 3:48 PM / IP Logged
I have to install daytime running lights (dtrl) on a US model 2000 Mitsubishi Galant.I dont want to use a dtrl module but instead use a relay thru ignition to low beam head lights.
I need to know the best way how to wire up a relay and if possible the wire color for low beam headlights.
Thanks in advance.
Posted: June 01, 2008 at 4:44 PM / IP Logged
It might be simpler than you think, I have a 2000 Uk spec Galant and it uses grounded leads at the switch, in other words a grounded feed will give you low beams.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
