2005 nissan altima, remote start
2003kawasaki
Member - Posts: 20
Posted: June 27, 2008 at 10:50 AM / IP Logged
I am looking to install a 561t into an altima 2005. I need a second starter wire for this. Can I use the 4 pin harness,purple wire and a relay for this?
Kurt
fcss
Copper - Posts: 92
Posted: June 27, 2008 at 10:57 AM / IP Logged
ya you can its a neg so like you said you will use a relay to convert it to pos.
2003kawasaki
Member - Posts: 20
Posted: July 07, 2008 at 1:42 PM / IP Logged
Can someone post a picture of the ignition switch from the back side so I can see the arrangement of the wires as in place. I need to know wich wire go to each opening of the plug. I am having problem starting my car now.
2003kawasaki
Member - Posts: 20
Posted: July 07, 2008 at 1:44 PM / IP Logged
I forgot to add in that it is for a Nissan Alitima 2005 4cyl
smcshark
Member - Posts: 34
Posted: July 07, 2008 at 2:55 PM / IP Logged
don't have picture
Batt Green
Ign 1 Black Red (Small)
Start 1 Black / red
Start2 Black / Yellow
Acc 1 Red
Automotive Electronic Specialist
Chris Luongo
Platinum - Posts: 3,746
Posted: July 08, 2008 at 7:42 PM / IP Logged
Just did one of those this morning.
Pretty much all Nissans use the same wiring plug, with the wires in the same locations, just with different colors.
If I remember right:
Hold the plug with the wires facing you, and the clip facing up.
Top left: constant
Bottom left, and center top: Starter wires
Center bottom: radio
Top right: ignition
Bottom right: climate controls
2003kawasaki
Member - Posts: 20
Posted: July 09, 2008 at 8:04 AM / IP Logged
I checked my wirers and every thing is fine, so I tried a new ignition key and the car started up with no problems.
