viper 5701le remotes beep, fail to arm
deneteus
Member - Posts: 12
Posted: June 28, 2008 at 3:40 PM / IP Logged
I have a Viper 5701 LE with the 2 transmitters. I can lock the doors and walk away and the alarm will fail to respond to the remotes both my 2 way and my one way remote. The 2 way will beep instead of returning a command. It randomly will allow me to disarm the alarm even if I am standing right next to the car. Not even a week before I was able to arm and disarm from inside a 6 story glass and steel building.
Does anyone have any ideas?
jar754
Copper - Posts: 142
Posted: June 28, 2008 at 5:06 PM / IP Logged
do you have new batteries in the remotes
deneteus
Member - Posts: 12
Posted: June 28, 2008 at 5:37 PM / IP Logged
i have the new batteries that came in the box 4 wks ago
joch1314
Copper - Posts: 301
Posted: June 28, 2008 at 6:31 PM / IP Logged
if it's not responding to either remote, check your antenna!  make sure it's plugged in properly at the antenna and also at the brain!!  If it's plugged in properly then something might be wrong with your antenna!  unlikely...but possible!
...half of the truth can be worse than a lie. <----Roger Russell said that..
