556hw bypass, 03 accord, 6 speed
knightrider2000
Member - Posts: 15
Posted: August 07, 2008 at 2:07 PM / IP Logged
I am about to begin my remote start install into my 2003 accord v6 6 speed. I have one question. I have a blue/white wire coming out of my bypass module that just says remote start. Does this hook into the remote start activation wire of my remote start unit? it is also a blue white wire.
I am installing a DEI python 950 into the car. I had hoped by getting all DEI equipment it would be pretty simple install.
Matt
Big Dog
Gold - Posts: 1,265
Posted: August 07, 2008 at 2:16 PM / IP Logged
That will be connected to the dark blue status wire which is in a four pin connector on the XCRS relay pack.
Prepare your future. It wasn't the lack of stones that killed the stone age.
knightrider2000
Member - Posts: 15
Posted: August 07, 2008 at 2:58 PM / IP Logged
Ok Great Thanks alot!
i have one more question.
On the main harness (small wired one) the WHITE/ blue wire that says remote start activation input. Where does this need to be hooked to?
All the book says is its set from the factory at 2 pulses.
Big Dog
Gold - Posts: 1,265
Posted: August 07, 2008 at 3:03 PM / IP Logged
Don't connect it anywhere. This is only used in systems where you'd use an auxiliary channel of a security system to control remote start.
moonliter
Copper - Posts: 322
Posted: August 07, 2008 at 3:34 PM / IP Logged
Is this a 6 speed manual tranny ?
knightrider2000
Member - Posts: 15
Posted: August 08, 2008 at 3:44 PM / IP Logged
Yeah Sure is!
enice
Silver - Posts: 857
Posted: August 08, 2008 at 5:22 PM / IP Logged
Then Im sure you need a 689m for the neutral safety wire.....That remote start alone is not meant for manual transmission vehicles...
KarTuneMan
Platinum - Posts: 7,056
Posted: August 11, 2008 at 8:03 PM / IP Logged
So....... what happened?556hw bypass, 03 accord, 6 speed -- posted image.
tedmond
Gold - Posts: 4,610
Posted: August 11, 2008 at 8:41 PM / IP Logged
he was able to program the bypass, left it in his garage, remote started it and now he has a lovely open view from inside to the garage.
...who needs a garage door anyways when you got a 2 meter opening !
well lets hope this was NOT the case.
Thursday, October 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
