escalade driver door locks
Matrix7333
Copper - Posts: 54
Posted: September 02, 2008 at 1:56 AM / IP Logged
Hello all, does anyone one know what kind of locks (negative/Positive) is used in a 2006 Escalade EXT?  I am trying to hook the locks up to a remote starter/alarm.  Got all working except am trying to get the driver door to unlock, the alarm has a negative unlock pulse.  What relay confiuration do I need if any?
Twelvoltz
Platinum - Posts: 2,384
Posted: September 02, 2008 at 7:01 AM / IP Logged
GM switched to a databus door lock configuration on their trucks in 2003. The easiest solution for you would be to pick up a module. If you are looking to retain the driver's door priority unlocking the XK01 would do the trick. If you do not want to use a module then you would need to do a reversal circuit inside each front door with the priority unlock to the driver's unlock relay trigger and negative pulses for the rear doors.
Matrix7333
Copper - Posts: 54
Posted: September 02, 2008 at 11:40 AM / IP Logged
Thanks, i have a module but it was just for passlock bypass (GMBP) I  just ordered the XK01, it will make things a lot easier.  I came across a module already installed called GM-DT1000, it had some gps device hooked up to it,  but the driver unlock priority don't work but it unlocks all the doors ok .
Thanks for your help.
