starter kill and anti grind
linedriver
Member - Posts: 17
Posted: September 20, 2008 at 12:09 PM / IP Logged
i will be doing my very first remote starter/alarm install of a polar start remote starter/alarm and i have a couple questions in general. would it be possible to use the 'ground out when running' feature along with starter kill output since their both negative outputs and use just a single relay for my starter kill and anti grind feature?
also, it has a wire which says 'priority door output', and a parking light output, both as a negative output. what do those 2 outputs do? i figured the positive door input would have been the trigger for the alarm or something.
also, if anyone has a wiring diagram for a 1990 nissan skyline, that would be great
KarTuneMan
Platinum - Posts: 7,056
Posted: September 20, 2008 at 8:18 PM / IP Logged
Priority door output is for door unlock. it's used to trigger the DRIVERS door unlock only. Then the "main" unlock" (second unlock)
will do the remaining doors....
Alot of units have both POS+, and NEG- parking light outputs. Use the one you need.
Posted: September 21, 2008 at 9:08 AM / IP Logged
You wil probably need a door lock actuator in the driver's door for that one, use your priority control to relay the unlock motor wire for that unit then lock all via the driver door sdded actuator lock wire.
