Using Brake As Kill Switch.
treacher
Posted: March 12, 2003 at 12:00 AM / IP Logged
hello i was wondering if there was a way to wire a car so that you would have to step on the brake in order to start the car. i want to do it to my car that already has an alarm with a starter disable but i just would like to add this extra precautionary measure. any help is truly appreciated.
CruisinS&S
Copper - Posts: 225
Posted: March 12, 2003 at 12:14 AM / IP Logged
https://www.the12volt.com/relays/page2.asp
Go to this section of this site
Under passive starter kill relaysjust use first relay diagramuse brake wire above pedal that shows 12volts when pressedto terminal 85 on relay
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
