horn honk
toofastgtp
Member - Posts: 15
Posted: October 11, 2008 at 1:40 AM / IP Logged
1998 Buick regal with python 990.
Would this be safe or do i need to make a relay set up
Horn honk wire from alarm to black ground horn wire at horn switch or you think this ground that triggers the relay under hood is more then 200ma
reax222
Copper - Posts: 220
Posted: October 11, 2008 at 9:35 AM / IP Logged
It never hurts to use a relay, but if the system already has a relay, I don't see any need in adding another.
JWorm
Platinum - Posts: 2,208
Posted: October 11, 2008 at 9:37 AM / IP Logged
No relay needed
toofastgtp
Member - Posts: 15
Posted: October 11, 2008 at 9:51 AM / IP Logged
Thank you!
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
