08 gx470 wiring diagram?
snake07
Copper - Posts: 79
Posted: October 27, 2008 at 10:42 AM / IP Logged
Hi all,
I'm looking for the wiring diagram for an 08 Lexus GX470.
Thank you in advance,
another-kelly
Silver - Posts: 618
Posted: October 27, 2008 at 11:26 AM / IP Logged
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Radio Security          YES
     Security
     Battery          WHITE/ BLUE          (+)          IGNITION SWITCH HARNESS
     Ignition 1          BLACK/ RED          (+)          IGNITION SWITCH HARNESS
     Starter 1          GREEN/ BLACK          (+)          IGNITION SWITCH HARNESS
     All Door Trigger
               YOU MUST DIODE ISOLATE BOTH TRIGGERS TO MONITOR ALL DOORS.
     LF Latch          RED / GREEN          (-)          AT VEHICLE FUSEBOX
     RF Latch          RED / YELLOW          (-)          AT VEHICLE FUSEBOX
     LR Latch          RED / BLUE          (-)          AT VEHICLE FUSEBOX
     RR Latch          RED / BLACK          (-)          AT VEHICLE FUSEBOX
     Alarm Disarm          GREEN/ YELLOW          (-)          IGNITION SWITCH HARNESS
               GROUND BEFORE AND DURING REMOTE START.
     Parking Lights          GREEN          (+)          TOP LEFT PLUG AT FUSE BOS OR DRIVERS DOOR SILL HARNESS
     Convenience
     Please select another category
     Remote Start
     Ignition 2          BLACK / YELLOW          (+)          IGNITION SWITCH HARNESS
     Accessory 1          WHITE/ GREEN          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          UNIVERSAL IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Tachometer          RED / BLACK          (-)          AT FIRST FUEL INJECTOR ON ENGINE
               NOT REQUIRED FOR REMOTE START, WILL START WITHOUT A TACH SIGNAL.
     Brake Lights          GREEN/ YELLOW          (+)          AT SWITCH ABOVE PEDAL OR DRIVERS DOOR SILL HARNESS
     Modules
     WIRE          LOCATION
     Doorlocks/Windows
     Power Unlock          GREEN W-SILVER DOTS          (-)          IN DRIVERS DOOR HARNESS
               DOUBLE PULSE TO UNLOCK ALL DOORS
     PowerLock          BLUE W-SILVER DOTS          (-)          IN DRIVERS DOOR HARNESS
snake07
Copper - Posts: 79
Posted: October 27, 2008 at 1:04 PM / IP Logged
Thanks a lot,
Do I have to remove the door panel to get into the Lock and Unlock wire ?
another-kelly
Silver - Posts: 618
Posted: October 27, 2008 at 10:16 PM / IP Logged
no. they'll be in the boot in between the door and the body. . .or if you can see where those wires come into the vehicle high in the drivers kick panel
kgerry
Platinum - Posts: 3,455
Posted: October 28, 2008 at 3:19 PM / IP Logged
if it's the same as my 06 you can grab locks in the passenger kick or else use a TOYDL and grab data low in the drivers kick.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
