Remote Start Anti Grind Feature
carhigh
Member - Posts: 24
Posted: November 06, 2008 at 8:17 PM / IP Logged
Two 2003 nissan sentras. Had  circuit city install these "Python 1400XP Remote Start/Keyless Entry Systems"
Link to product:
Says anti-grind in the features. I thought this was the thing that prevented you from getting in the car after it was remotely start, and turning the key to far and listening to the starter engaging?
Both of the cars seem to grind if we turn the key to far while the car is running off the remote start. I had a jeep with a remote start and it never did this crap!!
The anti grind isnt working on the sentra, is it?
t&t tech
Platinum - Posts: 2,622
Posted: November 07, 2008 at 5:20 AM / IP Logged
cary it back to the shop and let them check to see if they have the antigrind circuitry programmed on.
chriswallace187
Gold - Posts: 1,661
Posted: November 07, 2008 at 8:34 AM / IP Logged
Agreed with t&t tech...also you would want to make sure that they cut the starter wire in the first place when wiring to the relay satellite. Some shops don't do that for whatever reason.
C Renner's Auto Electronix
ckeeler
Gold - Posts: 1,461
Posted: November 07, 2008 at 9:46 AM / IP Logged
true, true isn't it? laziness abounds sometimes.
KPierson
Platinum - Posts: 3,527
Posted: November 07, 2008 at 10:33 AM / IP Logged
Wouldn't you need to add an extra relay to make the anti grind feature work with a stand alone remote start?  All the alarm/remote starts I've put in use the starter kill relay for the anti grind feature.  On a remote start / keyless unit you have no starter kill relay.
If you take it back to CC I would expect a charge for the relay and the installation to add this feature.
I've never seen it done through the starter relay as mentioned above - how exactly does that work?
Kevin Pierson
ckeeler
Gold - Posts: 1,461
Posted: November 07, 2008 at 10:55 AM / IP Logged
Ive seen many  RS/keyless units with no alarm that had a relay, some even built in with 2 wires coming out of the brain for the start wire. all OMEGA keyless entries have a starter kill relay with them. I have no clue why since its not an alarm only keyless entry, but none the less, they do.
robertsc
Copper - Posts: 337
Posted: November 07, 2008 at 11:03 AM / IP Logged
i never wire up antigrind
i also charge extra to do it
did you pay to hitched up?
usually after i explain to the customer that if they lock the vehicle
then  if  relay, they lose the remote  goes bad or it quits working that they won't be able to start there car
they usually decide they don't want it
ckeeler
Gold - Posts: 1,461
Posted: November 07, 2008 at 11:14 AM / IP Logged
how do you figure that? anti-grind relay should only be activated during remote start. once not activated, term 30 and 87a connect the start wire together, so even if you never had another remote again, the car is always going to start.
robertsc
Copper - Posts: 337
Posted: November 07, 2008 at 3:37 PM / IP Logged
the way dei piece work is that the anti grind output is also a ground when armed
that is the ORANGE / black wire
so as soon as you lock the car with the remote you also have starter kill
thats the way i always understood it worked
regal1975
Member - Posts: 14
Posted: November 07, 2008 at 3:41 PM / IP Logged
I dont see how they managed to not have the anti-grind feature on unless they programmed it out. I put in hundreds of the python 1600xp's and thousands of 562ts and never had one not anti-grind...
