2008 silverado, autopage remote start
gixxerboyz
Member - Posts: 14
Posted: November 16, 2008 at 8:55 PM / IP Logged
i just did a remote start on an 08 using an AutoPage rs and DEI 1701G module. i had to use a relay and add a couple resistors. it seemed to work just fine, now the next day it will not start. it cycles like it should but never cranks. everything else works fine, door locks etc, starts with the key no problem there. HELP!! im stuck. i used the wiring diagram from this website and followed it. what am i doing wrong??
gixxerboyz
Member - Posts: 14
Posted: November 17, 2008 at 5:43 PM / IP Logged
so now this morning it worked.  what is going on????
Mike M2
Platinum - Posts: 2,652
Posted: November 17, 2008 at 6:44 PM / IP Logged
My first thought is the resister value on the starter wire is incorrect....
Mike M2
Tech Manager
CS Dealer Services
gixxerboyz
Member - Posts: 14
Posted: November 17, 2008 at 8:22 PM / IP Logged
what watts should the resistors be?? 1/4,1/2 or 1 watt??
Mike M2
Posted: November 17, 2008 at 9:24 PM / IP Logged
Wattage is unimportant in this application. The Ohm value is what you need correct, which is 1280....
Mike M2
Tech Manager
CS Dealer Services
gixxerboyz
Member - Posts: 14
Posted: November 17, 2008 at 9:26 PM / IP Logged
it called for 9.6k and 6.3k, i used 1/4 watt resistors
Mike M2
Posted: November 18, 2008 at 6:36 AM / IP Logged
Sorry, forgot you are using a 1701G and the directions it comes with, they call for 9.6 on the start and 6.3 on the accessory. Avox has another method using just one resistor at 1280.
If you are not using the correct value(say you are off 10% or more) it will do what you describe. The 1/4 resistors are fine...
Mike M2
Tech Manager
CS Dealer Services
soundnsecurity
Gold - Posts: 2,720
Posted: November 18, 2008 at 5:27 PM / IP Logged
check for loose connections
harlin
Posted: January 24, 2009 at 12:23 PM / IP Logged
autopage either remote wont work after starting car but lcd beeps when run time done
any ideas?????????
harlin
Posted: January 24, 2009 at 12:26 PM / IP Logged
any ideas?
sorry posted in wrong spot...
Tuesday, January 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
