tach on ford, 05 e350
tsremodel
Member - Posts: 15
Posted: November 23, 2008 at 11:53 AM / IP Logged
Hey guys I just about got the remote starter / alarm installed. I am looking for the color code of the tach wire behind the cluster panel. I rather not go to the pcm if I can help it. Can anyone help?
Thanks guys
Tom
JWorm
Platinum - Posts: 2,208
Posted: November 23, 2008 at 12:38 PM / IP Logged
A Ford you say? How about a little more info than that?
tsremodel
Member - Posts: 15
Posted: November 23, 2008 at 12:53 PM / IP Logged
OPS HEHE Sorry guys. Its a 05 ford E350 super duty with a gas engine.
another-kelly
Silver - Posts: 618
Posted: November 24, 2008 at 9:47 AM / IP Logged
dunno the clusters, but you can go to a fuel injector using the odd colored wire at the injector (each injector has a common which is same at each injector, and an odd colored wire)
Mike M2
Platinum - Posts: 2,652
Posted: November 24, 2008 at 10:12 AM / IP Logged
My suggestion would be to look on the back of the cluster for the same color wire listed for the PCM...
Mike M2
Tech Manager
CS Dealer Services
Posted: November 24, 2008 at 11:05 AM / IP Logged
Suggest avoiding the instrument cluster. If it's like UK Fords (ha that's a laugh I meant German/Belgium and Spanish Fords) the instrument cluster might be a processor in itself and the tach wire might be data, DON'T TOUCH!  If on the other hand it has multiple plugs and a flexible printed circuit where you can trace back from the connections on the back of the tach, you're O.K.
tsremodel
Member - Posts: 15
Posted: November 24, 2008 at 11:38 AM / IP Logged
Not the same wire as the pcm thats what I thought yesterday. Good try though. :)
I think I'll be going to the injector wiring.
