2003 volkswagon passat remote start chart
Welcome Guest :)
criego
Member -
Posted: December 05, 2008 at 3:20 PM / IP Logged
Can Any one help me out with a wiring chart for a 2003 Passat remote start and bypass.
Thanks Alot
ckeeler
Gold -
Posted: December 05, 2008 at 8:17 PM / IP Logged
| 12 VOLT CONSTANT | RED (+) | IGNTION SWITCH HARNESS | |
| STARTER | RED / BLACK (+) | IGNITION SWITCH HARNESS | |
| STARTER 2 | N/A | | |
| IGNITION 1 | BLACK (+) | IGNITION SWITCH HARNESS | |
| IGNITION 2 | N/A | | |
| IGNITION 3 | N/A | | |
| ACCESSORY /HEATER BLOWER 1 | YELLOW/BLACK (+) | IGNITION SWITCH HARNESS | |
| ACCESSORY /HEATER BLOWER 2 | N/A | | |
| KEYSENSE | N/A | | |
| PARKING LIGHTS ( - ) | N/A | | |
| PARKING LIGHTS ( + ) | GREEN/ RED (+) | @ HEADLIGHT SWITCH | |
| POWER LOCK | RED / GREEN (TYPE B) | @ DRIVERS DOOR MODULE, See NOTE *1 | |
| POWER UNLOCK | RED / BLUE (TYPE B) (Requires Double Pulse) | @ DRIVERS DOOR MODULE, See NOTE *1 | |
| LOCK MOTOR WIRE | BLACK/ BLUE (+) | @ DRIVERS DOOR MODULE, See NOTE *1 | |
| DOOR TRIGGER | BROWN / YELLOW (-) | @ COMFORT Module, 23-Pin Plug, Pin 1, See NOTE *2 | |
| DOMELIGHT SUPERVISION | BLUE/GRAY (-) | @ COMFORT Module, 23-Pin Plug, Pin 21, See NOTE *2 | |
| TRUNK RELEASE | BROWN / GREY to BROWN / GREEN | @ COMFORT Module, 23-Pin Plug, Pin 2, See NOTE *2 | |
| SLIDING POWER DOOR | N/A | | |
| HORN | BLACK / YELLOW (+) (Alarm Horn) | @ COMFORT Module, 15-Pin Plug, Pin 11, See NOTE *2 | |
| TACH | Any wire NOT BLACK/ BLUE or GREEN/ RED | @ ANY FUEL-INJECTOR | |
| WAIT TO START LIGHT | N/A | | |
| BRAKE | RED / BLACK (+) | @ SWITCH ABOVE BRAKE PEDAL | |
| FACTORY ALARM DISARM | DISARMS WITH UNLOCK, First Pulse Disarms | | |
| ANTI-THEFT | TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES BYPASS MODULE AND EXTRA IGNITION KEY | TRANSPONDER @ IGNITION SWITCH TUMBLER | |
| NOTES |
| NOTE *1 the DRIVERS DOOR MODULE is located INSIDE the DRIVERS DOOR.NOTE *2 the COMFORT MODULE is UNDER the CARPET in FRONT of the DRIVERS SEAT in a PROTECTIVE BOX. |
Wednesday, May 20, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
