2006 grand caravan, starter, door locks
offdamap
Posted: December 15, 2008 at 1:55 AM / IP Logged
I'm installing a 560xv .
Does any body  have a relay diagram for the second starter and for the door locks thanks.
I found this website but they wire it for their alarm only.
http://64.85.6.129/extrainfo/diagrams/29358_CARAVAN_CHRYSLER%20MINI%20VAN%20STARTER%202%20DIAGRAM.pdf
thanks
KarTuneMan
Platinum - Posts: 7,056
Posted: December 15, 2008 at 12:31 PM / IP Logged
get yourself a module that will do all that for ya! simplify your life.... it's worth the extra money!
ceasar326
Copper - Posts: 239
This is for the second starter
http://documents.audiovox.com/700820.pdf
This is for single wire door locks
http://documents.audiovox.com/700649.pdf
Chassis Ground Thru A 5.3k To Lock And Chassis Ground Thru A 2k Ohm Resistor To Unlock.
or
This vehicle uses a 1-Wire Door Locking System requiring a (-)Negative thru a 5200 Ohm Resistor for LOCK, and a (-)Negative thru a 2000 Ohm Resistor for UNLOCK, some units will also require 2 extra relays
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
