astroflex model 800
mauri197
Copper - Posts: 80
Posted: December 30, 2008 at 2:55 PM / IP Logged
hey guys i have an astrostart model 800 that is doing nothing evrytime i hit the remote for it to start the led flashes the module sees the remote but no ignition no crank nothing and it doesnt send any flashes after that to try to figure out tanx its on a s10 pick up 2000 no power lock no windows tanx
moonliter
Copper - Posts: 322
Posted: December 30, 2008 at 3:45 PM / IP Logged
Count the number of led flashes after it fails to start.   Most likely problems are : x = number of flashes on the module
  • 4x no tach signal
  • 5x hood open
  • 8x switch is in OFF
mauri197
Copper - Posts: 80
Posted: December 30, 2008 at 3:50 PM / IP Logged
the led does not flash after i it the remote
moonliter
Copper - Posts: 322
Posted: December 30, 2008 at 4:13 PM / IP Logged
Well in that case, check for +12 volts at the module, make sure the ground & antenna is properly connected. After that, try to reprogram the remote.
dip sw 8 up, hit the brake once, press any button on the remote,  dip sw down & hit the brake once more. Try to remote to see if it works.
mauri197
Copper - Posts: 80
Posted: December 30, 2008 at 4:18 PM / IP Logged
tanx for the quick reponse but the remote programs i have a good ground and 12 volts going to it but it doesnt do nothing the led flashes when i hit the remote but it wont remote start and after that the led doe not flash
moonliter
Copper - Posts: 322
Posted: December 30, 2008 at 5:40 PM / IP Logged
Another thing I can think of, it has dc volt presented at the ign wire. It could be caused by a backfeed or a faulty ign switch. You might want to check it with a dmm.
mauri197
Copper - Posts: 80
Posted: December 30, 2008 at 5:59 PM / IP Logged
i just checked the ignition wire there is no feedback coming from the switch its really getting to me already
mauri197
Copper - Posts: 80
Posted: December 30, 2008 at 6:07 PM / IP Logged
is there a way to reset the system to where you have to reprogram tach and set it for automatic
moonliter
Copper - Posts: 322
Posted: December 30, 2008 at 6:14 PM / IP Logged
Is this a new installation or it just quits working ?
mauri197
Copper - Posts: 80
Posted: December 30, 2008 at 6:16 PM / IP Logged
it just quit working
