2006 dakota st alarm/remote start
06dak287
Member - Posts: 24
Posted: December 30, 2008 at 7:01 PM / IP Logged
hey guys. im getting ready to do my alarm/ remote start on my 06 dakota st base model no electric lock or windows.
ive got one question which ive never ran into before.
on the truck diagram for a couple of lights it says:
H/L pink/blue (example): negative triggered with a 112 ohm resistor, must use relay?????
what exactly does that mean? and how would it be wired?
im leaning towards the "negative door trigger relay example" in the security section
any help would be appreciated
06dak287
Member - Posts: 24
Posted: December 30, 2008 at 7:42 PM / IP Logged
noone? did i not state it right?
ckeeler
Gold - Posts: 1,461
Posted: December 30, 2008 at 8:13 PM / IP Logged
it means it must be triggered with a negative pulse "THROUGH" a 112 ohm resistor and it is NOT low current so you must do it through a relay.
06dak287
Member - Posts: 24
Posted: December 30, 2008 at 8:24 PM / IP Logged
ok im kinda getting it. so how would that be wired?
lets say im doing dome light with my alarm. it says negative trigger through a resistor. how would that be wired? does anyone have a diagram or...
Mike M2
Platinum - Posts: 2,652
Posted: December 30, 2008 at 8:30 PM / IP Logged
I'm confused. You want to connect the domelight supervision or door trigger? neither need a resistor. Is this example hypothetical? What exactly are you trying to do?
Mike M2
Tech Manager
CS Dealer Services
06dak287
Member - Posts: 24
Posted: December 30, 2008 at 8:45 PM / IP Logged
ok example. since my truck has manual everything.
the TRUCK'S diagram says:
parking lights- (blue/white)-whatever. than it says: lights are negtive trigger through a # resistor. MUST use relay.
how would that example be wired up for my alarm?
i hope that is clear becuase im confused with this whole resistor thing
t&t tech
Platinum - Posts: 2,616
Posted: December 30, 2008 at 9:48 PM / IP Logged
"ckeeler]it means it must be triggered with a negative pulse "THROUGH" a 112 ohm resistor and it is NOT low current so you must do it through a relay."
like ckeeler said, ur hooking ur parking light output through a relay wired to give a negative output, u place the 112ohm resistor in line betwwen the negative output of the relay and the car's park light wire, you can look in the relay section of this site, for info on how to wire your relay accordingly to the type of park light polarity on the alarm, if ur still unclear post back.
commit your way to jehovah and he will act in your behalf. psalms 37:5
06dak287
Member - Posts: 24
Posted: December 30, 2008 at 9:55 PM / IP Logged
ok so the color wire stated in the schematics that is negative triggered, would be the wire i tap into and then between THAT wire and the relay goes a resistor? and from there hook up the 12 volt and back to the alarm brain?
06dak287
Member - Posts: 24
Posted: December 30, 2008 at 9:56 PM / IP Logged
could you please draw up what it should look like?
t&t tech
Posted: December 30, 2008 at 10:07 PM / IP Logged
ok, i don't know if the wire u stated as being the park light wire is or not, you have to verify using a meter, but her's how u connect it, i'm assuming here ur alarm's park light is positive polarity, if it's not post back. the park light from the alarm connects to the terminal labelled positive trigger on the relay. and the resistor goes between the negative output of the relay and the car's park light wire.
2006 dakota st alarm/remote start -- posted image.
Thursday, September 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
