2008 tiburon power locks.
jinstall
Copper - Posts: 67
Posted: January 18, 2009 at 12:54 PM / IP Logged
hey guys I've had a couple of topics I started on this car, but now that I've done it I wanted to alert you guys to how stupid the lock system is and what you have to do, it's niot that bad but it's a bit of a surprise when your installer support tells you one thing and it doesn't do what it's supposed to.
the locks on this car are a one wire system. instead of a traditional multiplexed resistor type system you have to cut and isolate the wire. open circuit is lock and ground pulse is unlock. the problem is once you do this on the drivers side you'll lock both doors but the passenger side won't unlock. what you have to do is isolate the wire going into the doorlock motor on the passenger side through a relay just like on the driver side.
wire colours on the car I did was yellow on the driver side and blue on the passenger side. on the driver side the yellow wire goes into the front of the fuse box in it's own little connector. the passenger side you gotta look for it a little harder in the loom coming in from the door.
not the toughest thing but it's a surprise, so there's your info in case you come across one.
kassdog
Copper - Posts: 257
Posted: January 18, 2009 at 1:46 PM / IP Logged
Just a fyi, that passenger wire is also in the fuse box. Every I have done I have had all my wires at the fuse box for locks. Its a really easy car today but yeah the door locks are wierd.
Tuesday, July 1, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
