2006 dodge ram cruise control prob after
newman2ng
Member - Posts: 7
Posted: January 18, 2009 at 1:07 PM / IP Logged
Installed a galaxy 1900rs in a 2006 dodge ram diesel. Eveything went good and the start works great when the customer left he said that the squares around the shift Indicators in the dash only lit up in park and nuetral. On his way home he said he tried the cruise control and it wouldn't work. Just before getting home his check engine light came on. Is this something with the remote start? I used a pkuch2gx which I use on all newer dodges and have never had a problem like this. Any pointers? Thanks
12vstunna
Member - Posts: 16
Posted: January 18, 2009 at 1:15 PM / IP Logged
tell me what wires you grabbed xactly i think i can help you
WHO NEEDS M.E.C.P ITS JUST A CERTIFICATE,OH AND I GOT THE SKILL TO PROVE THAT I DONT NEED ONE~XxX12vStunnaXxX~    X-Mobile Solutions
newman2ng
Member - Posts: 7
Posted: January 18, 2009 at 3:15 PM / IP Logged
Power at ign harness
Start. At ign harness. GREEN/ YELLOW+
Ignition at ign harness. Pink/white+
Mux wire at ign harness. PURPLE / brown-(from bypass)
Brake. At pedal.   White tan+
Parking lights at harness. WHITE/ green-1130 resistor through relay
12vstunna
Member - Posts: 16
Posted: January 18, 2009 at 3:26 PM / IP Logged
im sure your prolem is power i think i had that problem when they first came out only my install went worse i ble out the computer so well now im gonna help you out
12 volt -12ga ORANGE / red in connector next to parking brake yes thats correct the parking brake
ign. pink white at ignition harnes
starter GREEN/ YELLOW
o it looks like all your wire is cool but power try that and unplug the battery and well it should fix your problem its funny but that wire at the ign harnss is a no no on dodge,for som reason dodges are picky on the way they like to be touched so do as i said and you should be good
12vstunna
Member - Posts: 16
Posted: January 18, 2009 at 3:29 PM / IP Logged
oh and lights use same wire but give it 3.3k ohm resistor (negative lights)oh and if alarm has negative output on lights remove relay its realy not needed
Friday, November 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
