2006 audi a6 i need ignition info
get wired
Member - Posts: 17
Posted: January 29, 2009 at 8:16 PM / IP Logged
I ran into an issue today with an a6.  The 2006 model has a data operated ignition system and I was wondering if there was a soul out there that has successfully bypassed this issue  without using the $583 fortin module.
I have access to all the tech notes, so please that's not what I need. I need some mastermind to explain how they made theirs work. Thanks to all, and good luck!
Scott Gillis
Owner of Get Wired
Massachusetts
t&t tech
Platinum - Posts: 2,622
Posted: January 30, 2009 at 4:55 PM / IP Logged
paging howie please, go easy on him he meant to say audi,2006 audi a6 i need ignition info -- posted image.
Posted: January 30, 2009 at 5:28 PM / IP Logged
Forget it!!!!  You'll be dancing the CAN CAN over this one. Audi,  shmaudi, I've driven 200 miles today, it's lovely working out there in the dark and sub-zero waiting for a cranky tracker to come on line, stop laughing t&t what's the temp where you are ? I've run a mile from every post 2005 audi, my only suggestion would be to try one of the other firms if Fortin can't help. The other alternative would be to buy another ignition receptacle, parallel it with the original and bury a key. No that won't work unless you then feed ign and starter outputs at the fuse box.
get wired
Member - Posts: 17
Posted: January 30, 2009 at 5:45 PM / IP Logged
Yeah it's a pretty tough situation. I really didn't want to have to tell this guy it can't be done but I might have to.  Thanks for your input friend.
Scott Gillis
Owner of Get Wired
Massachusetts
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
