ultra start troubleshooting
carlink
Posted: February 07, 2009 at 11:18 PM / IP Logged
I have a XR-2280 Ultra Start alarm in my 04 Dodge Ram and each morning between 3:00am -  5:00am the alarm turns on and I do not know why, can somebody tell what are the reasons for this happen?
tama1980
james bond 007
Copper - Posts: 62
Posted: February 08, 2009 at 1:12 AM / IP Logged
could be moisture in the door pin switch, give them a shot of wd40, if that doesn't work i would start by disconnecting the hood swich try it out and go from there
carlink
Posted: February 08, 2009 at 8:05 PM / IP Logged
This problem start when I conect the relay for domelight.
tama1980
Chris Luongo
Platinum - Posts: 3,746
Posted: February 09, 2009 at 7:02 PM / IP Logged
Pretty much every alarm has some way of telling you what "zone" was violated the last time the alarm went off.
It's probably in the owner's manual, but usually you count how many times the alarm's LED flashes after you disarm it.
So, after learning exactly how to do it in the owner's manual, arm the alarm, wait until it falses again, and then see what zone it was............door, hood, trunk, shock sensor?
Friday, January 30, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
