98 dodge avenger, python 1400xp
jla74
Member - Posts: 21
Posted: February 11, 2009 at 8:44 PM / IP Logged
I am putting in a remote start on the 98 dodge avenger and need to know what bypass module I can buy to get around the factory security system.  I am installing a python 1400xp.  This car had another remote start in before and was never installed correctly.  The accessoris weren't hooked up and when ever I locked the doors with anything besides the aftermarket remote the alarm went off when I unlocked the doors and got back in the car.  This is what I am trying to avoid.  From what I have been able to find is that it is controlled by a transponder??  Thanks
SoundImage
Copper - Posts: 75
Posted: February 11, 2009 at 10:45 PM / IP Logged
you shouldn't  need a bypass
jla74
Member - Posts: 21
Posted: February 12, 2009 at 6:58 AM / IP Logged
So the 1400xp will take care of the disabling of the alarm no matter how the doors are locked?
loneranger
Copper - Posts: 572
Posted: February 12, 2009 at 1:10 PM / IP Logged
  • You don't. Bypasses are for anti-theft,  transponder, and other types of overides.
  • You assume.
  • Without your original R/S make and model, it would be difficult to determine the abilities.
  • That is in-correct.
  • If it's integrated properly, yes.
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
jla74
Member - Posts: 21
Posted: February 12, 2009 at 2:20 PM / IP Logged
Ok so are there any suggestions for a proper integration?  I am curious about the preexisting R/S though and since I will have to remove it to install the new one I will post some info.  Thanks
jla74
Member - Posts: 21
Posted: February 12, 2009 at 6:44 PM / IP Logged
Auto Command 29936 is the previous R/S
jla74
Member - Posts: 21
Posted: February 12, 2009 at 9:45 PM / IP Logged
Ok, so I started the install and ofcoarse I ran into a couple of questions.
1:  Blue second unlock wire.  There isn't any clear definition where this gets connected. ??just give a definition of what it does.  Any one able to help?
2: WHITE/ blue (-) remote start activation input.  This as well give a good definition of what it does but only shows a picture of a button with one wire on one connection and the other ot ground.  Now I have similiar looking button in the pack but it has a connection on it that hooks to the brain. (valet program switch)
3: orange (-) ground-when-armed-output.    Do I need to hook this up some where?
4: GREEN / WHITE factory rearm output.  Ok the wiring diagram tells me about the disarm wire (
Factory DisarmLight GREEN/ Orange Driver's Door Boot or GREEN / WHITE Driver's Kick Panel
but nothing about the arming wire.
sorry for the questions but the instructions are not as clear as I would like.  Thanks
loneranger
Copper - Posts: 572
Posted: February 13, 2009 at 1:46 PM / IP Logged
1. Used for progressive unlock feature.
2. Used for remote start activation feature, by pulsed input.
3. Used for starter-kill or anti-grind feature.
4. More information will be needed, regarding how the factory alarm can be armed(ie. key-lock pulse, factory arming wire).
jla74
Member - Posts: 21
Posted: February 13, 2009 at 2:18 PM / IP Logged
Hey Loneranger - Thanks
1. so if I just want the doors unlocked with one button press I don't need it?
2. If I am only using the remote fob I don't need it?
3. No starter kill or anti-grind so I don't need it?
4. arms automatically with a door lock by manual or remote.
loneranger
Copper - Posts: 572
Posted: February 13, 2009 at 6:32 PM / IP Logged
1. No and all doors will unlock at once, with no progressive unlock.
2. No and using the R/S remotes, not the factory K/E remotes.
3. No and anti-grind(PURPLE and GREEN - XCRS) is built-in.
4. By manual, do you mean physically operating the door-lock switch or driver's key-cylinder?
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
