2005 volvo s40 wiring
nei00755
Copper - Posts: 61
Posted: February 19, 2009 at 9:31 PM / IP Logged
Does anyone have the remote start wiring for a 2005 Volvo S40?
loneranger
Copper - Posts: 572
Posted: February 19, 2009 at 10:51 PM / IP Logged
WIRECOLORPOLARITYLOCATION 2005 volvo s40 wiring -- posted image.
2005 volvo s40 wiring -- posted image.BatteryRED (15 AMP)(+)IGNITION HARNESS
2005 volvo s40 wiring -- posted image.Ignition 1GREEN / WHITE(+)IGNITION HARNESS2005 volvo s40 wiring -- posted image.
2005 volvo s40 wiring -- posted image.Accessory 1YELLOW(+)IGNITION HARNESS2005 volvo s40 wiring -- posted image.
2005 volvo s40 wiring -- posted image.Starter 1GRAY/BLACK(+)IGNITION HARNESS2005 volvo s40 wiring -- posted image.
2005 volvo s40 wiring -- posted image.Anti-Theft TypeTRANSPONDER
2005 volvo s40 wiring -- posted image.Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
2005 volvo s40 wiring -- posted image.Key SenseRED / GREEN(+)IGNITION HARNESS2005 volvo s40 wiring -- posted image.
2005 volvo s40 wiring -- posted image.TachometerUSE FUEL INJECTOR(AC)ODD COLOR WIRE
2005 volvo s40 wiring -- posted image.Speed SenseBROWN OR WHITE(AC)AT ABS MODULE UNDER HOOD ON LEFT SIDE
2005 volvo s40 wiring -- posted image.Parking LightsBLACK/ BLUE(-)AT VEHICLE LIGHT SWITCH2005 volvo s40 wiring -- posted image.
2005 volvo s40 wiring -- posted image.Low Crr. Pk LightsBLACK/ BLUE(-)AT HEAD LIGHT SWITCH2005 volvo s40 wiring -- posted image.
2005 volvo s40 wiring -- posted image.Brake LightsORANGE(+)AT BRAKE LIGHT SWITCH ABOVE PEDAL2005 volvo s40 wiring -- posted image.
2005 volvo s40 wiring -- posted image.Reverse LightsGREEN/ BLACK(+)DRIVERS KICK PANEL2005 volvo s40 wiring -- posted image.
2005 volvo s40 wiring -- posted image.HornBLACK/ BLUE(-)AT THE STEERING COLUMN HARNESS2005 volvo s40 wiring -- posted image.
2005 volvo s40 wiring -- posted image.Rear DefrostBLACK/ WHITE
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
Posted: February 20, 2009 at 11:44 AM / IP Logged
Strange those colours for ign, acc and are ford Focus, OK GREEN/ YELLOW ign for the focus, yet the S40 was based on a Mits Charisma, both cars were built in Holland.  The current S50 IS Focus based, not the old US shape the current European shape.
